Question about Kenmore 88752 Top Load Stacked Washer / Dryer
Water pump making noise
Washer was pluged up with a dime, i fixed that problem now pump makes noise when draining. Could pump be going bad?
  • 770 Answers
If the dime was pulled from the pump it most likely damaged the impeller and the pump should be replaced
Posted on Jan 23, 2008
Ok I have a Frigidaire combo FEX831fs1. It won't drain. I replaced the pump and the belt. still wont drain. In the drain cycle it makes no noise at all. Spins, fills, agitates, just wont drain.
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed.
Read more:
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Fix Washing Machine That Won Drain Washer Not Draining Water
Apr 11, 2017 | Frigidaire Washing Machines
Hello,the drain hose COULD be plugged.
Mine had the PUMP INLET plugged with lint/dimes.
That's right, three dimes and some lint kept the water from getting to the pump.
For even an inexperienced handiman, the fix is easy.
2) Open access door in middle of back panel - 4 screws
3) Disconnect pump inlet hose - pump is on the floor/left as you face the inside from the rear. Have lots of towels handy as water will run out of the tub. This is a simple hose clamp - you dont have to remove the clamp - only loosen enough to remove the hose.
You can tell the inlet hose as it comes from the tub.
The outlet hose exits the pump and exits the machine.
4) stick your finger into the pump inlet and feel for any debris. I have found much lint and small coins. Somehow dimes get into the pump inlet and make perfect check valves preventing water from getting into the pump.
Remove the debris.
5) reconnect the pump inlet hose
6) replace back access panel.
7) plug back in and test.
If it does not drain now, you may need a new pump.
For even a handyman with four thumbs, this procedure should take less than 30 minutes !
May 24, 2010 | Kenmore 45087 Front Load Washer
Water pump out??
The washer filled with too much water, causing a switch to trip. Then everything stops. It tries to drain during FL but if it can't drain, the washer powers down.Choose Drain & Spin to let the washer drain. Then you have to take the washer apart. Fix the problem. I personally can't tell you what to do because I don't own a Calypso.
Bad Pump
High Water Flow
Other Causes
Jul 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirpool Duet front loader ghw9100lw error code F02
if your hearing clackling try and clean the pump and the hose leading into the pump for a coin ,,small ,,(dime),,,hair clip,,also its a must that you use he detergent,,or you sude up,,if you do use he your using to much,,now bleach the unit out on a normal cycle hot wash cold rinse with about a pint of bleach...and no you can purchase part of a comes as you see it in unit..onthejob
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
3.5 super capcity front loader
The drain pump had $0.86 in it (three quaters, a dime and a penny), a gaurdian angel medal and a sock stuck in the pump inlet. It was easy to fix by removing the lower fromt cover (two srews), taking off the spring clamp on the hose at the front of the pump and removing the rubber trap hose thingy.
Oct 07, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer making a weird noise
I didn't get to answer this but It makes "cents" to me.
Sep 09, 2008 | Kenmore Oasis HE 27062 Top Load Washer
forgot to include the most important step! We got the dimes out after wadding up a small piece of duct tape, sticky side out, and using locking forceps to grip the tape while fishing out the dimes from the drain pump.
Sep 03, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washer will not drain or spin motor making clicking noise
Likely has debris in the filter.
Open the bottom access panel (3 screw on bottom front lip)
open the filter access and be ready for some water spill ,have towels.
clean and check the pump impellers for freedom of movement.
if you still have noise after this you may have to go deeper past the pump and remove the hoses as the debris can be past the pump now.
Or take the machine outside and run water up the pump using a water hose to clear it. be inventive
Oct 26, 2007 | Whirlpool GHW9100L Front Load Washer
Neptune washer makes horrible noise - now won't drain
Does the washer make noise while the drum is spinning? Or, is making noise when the drain pump comes on? If the drum is spinning and making a lot of noise the rear bearings are usually bad. They cannot be removed from the drum, however. The entire outer tub shell has to be replaced, because the bearings are molded into the plastic. If it's only making noise when the drain pump comes on during the drain cycle, your drain pump may be obstructed in some way, or the pump itself could be bad. Getting inside the machine to check either component is not easy, because the door has to be removed, along with the front panel, rubber door seal, and top of the machine. Sorry, this may not be an easy fix for you. But, I hope I can lead you in the right direction. Let me know if you need further guidance.
May 25, 2007 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 88752 Top Load Stacked Washer / Dryer Logo
91 people viewed this question
Sal De
 Brian Main
Brian Main
