Question about HP PE4240N 42 in. HD-Ready Plasma Television
Hp Pe4240n 42' plasma tv
My tv color is green and red. There is lines running up and down.  I do have sound but the picture is pretty much gone.  I tried to reset it but that didnt work either
  • 1 more comment
  • bigkiddjp Nov 06, 2007
    My HP PE4240n 42" Plasma TV is not working properly. I was checking this site to see if any others had the same problem. When you turn on the TV, the screen shows a fuzzy blue color and when you change thennel, sometimes white lines appear (running from the top and bottom) in either the left hand corner, or when the channel is changed, it will appear in the center. There is never a black screen that displays the input for the TV, such as Video1, Video 2 or otherwise. I spoke to our cable provider to determine if it could be the cable box and based on the connection, we (the rep and myself) it was probably the TV. I am curious to know if anyone else is having a similar problem?
  • bklein Dec 02, 2007
    Same problem here - just bought the set from a private party. When it comes on it flashes a blue led then red led. The screen goes through a snowy change of colors - orange - green - blue - then the channel comes on with audio but video is a bunch of vertical color lines. If you get a blue background color screen the channel or whatever text is white vertical lines.
    The owner said this set died after a power outage in the area.
    Would like suggestions and/or service manual. I haven't opened it up yet...
  • Anonymous Dec 04, 2007
    Happy Holidays Guys. Question: Has either you received a response to your inquiry? I havent seen anything posted here yet, but was wondering if you found a solution on your own?
  • 36 Answers
Here's the number to HP case management 877-917-4380 ext.79, try this number and be firm that they need to fix this, I just had an HP plasma that was 3 yrs old replaced for free, no charge. Good luck
Posted on Feb 04, 2009
SOURCE:
I have a RCA 42"
The YSUS control board has failed from the description given. This is typical of the symptoms presented. It can be removed fairly easily and sent to a repair center to be repaired.
Nov 28, 2017 | RCA P42WHD33 42 in. Plasma HDTV
I have a black line down the middle of my screen on hp pe4240n plasma. how do I get it to go away
haha!! got the same problem with mine.you could check in youtube,they got a viedo how to fix it.I tried in mine and the line went away.the problem resides in some simple resistors ( i believe). if you open your tv,it has like type phillis screws in the back ,you'll see rome kind of ribbon wires from the tv chassis(exactly from boards) that going into the screen ,these ribbon wires have small electronical pieces(don't remember the name right now) that tends to get loose for overheating and if you have some little practice in getting your hand in a lead solder,you could fix it yourself realtive easy.just have to reweld on top of them.there's a few of them(ribbon wires) just look for the one closest to the vertical line and reweld those resistor,being carefull not to burn the ribbon wires.....good look and let me know how it went.......
Nov 02, 2010 | HP PE4240N 42 in. HD-Ready Plasma...
Screen gone yellow and green
I have a 21'' NEC TV Screen and it about 3 year old. the colour has gone to yellow and green color and the red etc
May 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
Gateway plasma
Sounds like your Y-Z sustain boards. You will need to get pro help and you should be looking at a repair or 400.00
Classtorations.com
Jun 12, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
HP PE4240N Lines in picture
go to this link and read carefully!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Dec 20, 2007 | HP PE4240N 42 in. HD-Ready Plasma...
Maxent 42' Plasma sound but picture looks like red, green and whites digital specks
the color card in the plasma is not okay.ihad the same problem and fixed it.
Apr 25, 2007 | Maxent MX-42HPM20 42 in. Plasma HDTV
Plasma tv vertical lines
I am getting a vertical green line on my lg 50 incs is the screen or have you a solution
Sep 03, 2006 | Sony WEGA KZ-42TS1 42 in. Plasma...
HP PE4240N 42 in. HD-Ready Plasma Television Logo
178 people viewed this question
Top HP Televison & Video Experts
Thomas F. Schneider
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
