Question about Nintendo DS Console
DS blinks and will not turn on
Hi, I changed the case for my sons ds screwed it back together and it blinks and will not turn on?
  • 709 Answers
Hi
As complicated a console as the DS is, it is not surprising you have a problem after changing a case. Sometime the little snap on wires do not snap on right.  You need to go back in and  make sure the ribbons and snap on connectors are sucured. The ribbon and wire that runs from top half through the hinge needs to roll up one turn before in the transition from the top to bottom half.  You may have the ribbon upside down in the connector.
Posted on Oct 28, 2007
My stylus is stuck im my ds stylus holder
Is it too big for it? If so, you might want to try this: the stylus holder is screwed on to the inside of the backing case.
if you remove the case back you can remove the stylus holder and then the stylus and put it back together.
Be careful when taking it apart and putting it back together not to break the power switch off, it is extremely delicate. turn the speakers all the way down and make surethat the slides are in position before putting the case back on.
Oct 16, 2010 | Nintendo DS Console
Hello...i have a problem with my son's ds lite, the hinge is broken, can it be fixed?
yes check ebay for hinge axle ds lite, from what i understand their are 2 types so make sure its for ds lite, should be around £4.99 with a screw driver lol
Jan 23, 2010 | Nintendo DS Lite Console
Mario and sonic ds
To change the language you must first remove the game chip. Turn on the DS and you will find a "gear" icon which allows you to choose different play options, including language.
Feb 06, 2009 | Sega Mario & Sonic at the Olympic Games...
Nintendo ds lite flashing top screen
i had a similar problem to this, i would check the connector strap in between the two screens if it is just one pin out this can happen
Jan 25, 2009 | Nintendo DS Lite Console
My son got a broken stylus stuck in the stylus holder help
Yes I can help you, the stylus holder is screwed on to the inside of the backing case.
Dec 28, 2008 | Nintendo DS Console
Broken bottom screen
Some of the screws are hidden.
-2 under rubber feet (bottom of console) - just prise the feet off - they just stick back on when refitting.
-1 screw (when the console is upside down) is in the middle of the cartride entry point - small black tri-wing screw.
Failing that check out YouTube - there are lots of videos showing how to take the case apart and put it back together again.
Sep 03, 2008 | Nintendo DS Lite Console
Nintendo DS Lite
If you want get some tools and take the ds apart.make sure all the pieces are straight and are put together right.if there not straight,make them straight.if there not put together,put them back together.Hope it works.
May 23, 2008 | Nintendo DS Lite Console
How to open ds lite
There are two cross head screws under the rubber feet at the slot1 side, there are two tri-wing screws on the left (stylus side) and inside the battery cover (under the battery) there is a cross head screw at the top and a tri-wing screw at the bottom (in the corner).
The screen is held together by 4 screws under the ruber pads and then the outer case slides up about 5mm and then pulls clear.
Take great care when putting it all back together to line up the volume and power switches and plastics as the power switch breaks quite easily.
HTH
Mar 02, 2008 | Nintendo DS Lite Console
Ds Lite
You may buy the screws here:
nintendo-ds-and-ds-lite-screws-and-springs
But my opinion is to go to a hardware store with a sample (cant be too long, the original ones are aprox 3mm long X 1mm diameter), try to find screws that fit and use normal philips screws instead these tri winding screws as you would need a tri winding screwdriver to put the original screws in place. All the screws in the NDSL screw in the plastic case except for the battery one that screw in a squared nut.
Good Luck...
Dec 16, 2007 | Nintendo DS Lite Console
Nintendo ds
Hi Tracey,
I have very good experince in repair of the DS. It is very very Complicated and loaded with detail, that if I told you what to do and how, it would take up to an hour to write. I know where all the ribbon cables go and how to hook them up and how to thread the ribbon cable and wire from the flip up monitor to the base.   Allow me to offer to repair your DS, and I will offer the reasonable price of $20 including return shipping.  No charge if I  put it back together and it still doesn't work. All of the DS Consoles I have put back together worked good. I have not rebuilt a DS lite before.  I am sure it is even more complicated.
I run the website www.playstationclinic.com, you can contact me from there if you like.
Oct 18, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
52 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
