The camera worked fine and so did the flashlight now both are messing up.
SOURCE: Camera not Working
ok tyr to reset ur phone in master reset or u have to change the camera belt or the camera
SOURCE: My LG env camera won't work any more
Well I had that problem and I called verizon. Then they sent me a new phone. So try calling them and see what happens. They will most likely send you a new phone or have a solution for it. Sorry I did not have a answer to help you right now but thats my best suggestion.
SOURCE: Razr V20 Camera Doesn't Open
There are a couple things that may be going on here:
1) Take it back to the carrier and see if they will replace it. Just tell them that the camera doesnt work. You dont need to volunteer that it was wet. They will be able to tell if they want to. If it was wet, your warranty is voided and they dont have to replace it.
2) rain has parts of dust and dirt in it. Drying the phone in the sun would have left that dirt behind and it could be on the connectors where the phone's main board meets the camera. The only fix for this would be to take the phone apart and try to clean the phone with rubbing alcohol QTip.
3) The battery, when it got wet sent a surge and short circuited the camera.
4) This is definitely a hardware issue and not a software issue. Here is a solution from another expert on this site: https://www.fixya.com/secure/support/t124873-camera_says_unable_open_camera,
If you are not comfortable taking the phone apart, then dont.
SOURCE: my nokia 5800 camera isnt
1st check camera and camera connector.
2nd u have change camera filter ic. just near of camera connector.
