Question about Sharp Aquos LC-65GE1 65 in. HDTV-Ready LCD Television
Canterlever wall mounting a Sharp LC -65GD1E.
Has anybody managed to fit one of these big TV's to a canterlever system to a wall (is there a canterlever that can handle these monsters). The tilting bracket system is no good for our application.
Regards
Chris Miller
  • Chris Miller Nov 21, 2007
    Thanks for the information We have decided to have the unit fitted by a specialist firm who deal in this sort of equipment. As soon as it has been completed I will post my comments and recommendations.
    Regards
    Problem Solver:
  • 8 Answers
Yes it is possible as while the television is BIG it isn't actually that heavy.  You will need a very good based to fix up against and I would have to strongly suggest using an expert service from a local AV shop.
Something like this would be ideal: http://www.ebuyer.com/product/130803
Some things to check:
1.  Fix to good quality brick work or very solid wood.  Modern partition walls aren't going to hold the weight and will damage both your wall and the television.
2.  Check the screws and rawl plugs supplied with the cantilever wall mount and replace them if they do not look deep enough or of suitable quality.  Ideally use something like an expanding radiator bolt.
3.  A lot of wall mounts provide more holes in the backing plate than screws are supplied... feel free to use more...!
4.  I like to think I'm pretty competent at DIY... but given how much I like mine I would be cautious and might just upgrade my home insurance to cover "accidents" :)
Posted on Nov 18, 2007
I have a cable paid for but My male coaxial cable from the wall doesn't fit into the antenna-in on the UN40c7000. It seems I need a coaxial cable adapter. I can't find the right size. How can you help?
Is the connector coming out of the wall too big or too small for the connector on the TV? If too big you should be able to still plug it in it will just be loose, and you can check that your signal is working etc.
This is very strange as coaxial cables have a very standard size, and do not vary. Unless it is a mini coax cable which is very tiny and right off the bat you can tell it wont fit. If that is the case then you need to get a converter.
Otherwise you may be able to use something like this http://www.amazon.com/10pcs-Frequency-Barrel-Connectors-Couplers/dp/B0037JB75S/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1381528325&sr=1-1-catcorr&keywords=coaxial+barrel
and tape the one end and use a regular cable to your TV. I would first purchase another cable and ensure that it will fit on the TV to ensure the connector on the TV is indeed the right size.
Oct 11, 2013 | Samsung UN40C7000 TV
My Monster Power HT700 will not stop beeping?
You have too many things plugged into it that require too much power. The Monster Power HT700 can not handle the pass-thru requirements needed to power your equipment. This beep is a warning that you are over drawing the Monster system.
Please rate if this helped :)
Mar 18, 2011 | Televison & Video
We have no instructions for the wall mount on the entertainment system that we are using with the lg47le5400 tv. I would like to know what hole we use and what screws to mount it. we recieved no...
the wall mount should have came with the proper screws to fit the back of your tv, if the screws fit the mounting holes on your wall mount, fit the larger screws that came with your tv through and make sure its tight, if so it should work.
Jun 26, 2010 | LG 47LE5400 47 in. TV
How do I wall mount the 65" TV. There are no instructions in the manual provided with the TV
You can buy a universal wall mount the will fit on that 65" plasma that comes with all necesary hardware and instructions to mount the TV to the wall. Now that 65" tv is really heavy so it needs good anchors to support the weight of the display.
Jan 02, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Monster connectors not like cable connectors
You were sold an HDMI cable. You need a coax. Wrong cable.
Jan 18, 2009 | Monster Cable (305007B)
How to remove the extra tire.
The tools to remove the spare tire should either be behind the bench on the floor or wall, or under the rear seat (king or crew cab) in a trap door. The instructions for removing the spare are printed on Tyvek paper and should be zip tied to the tools.
Hope this helps!
Jan 06, 2009 | 1999 Chevrolet Silverado 1500
Flyscreen match
I emailed them about fitting one on the GT1000 and here is the response from Steve: "The Monster brackets will not fit the GT1000 as far as I know. As soon as we manage to find one in this country we will look at whether it will be possible. So far I haven't seen any of the sport classics except at shows. I'll keep you informed!" I wouldn't mind modding the brackets to fit one..
Nov 20, 2008 | 2006 Ducati Sport 1000
Size drive chain Ducati monster 695 (2006) 520?
I don't know but I'd think the info you seek would be clearly marked on the chain itself or you could always measure the thickness of the sprocket surely it would be between a 520 and 530
Nov 20, 2008 | 2008 Ducati Monster 695
Wall mount doesn't fit holes on tv
As your learning a universal wall mount won't work on this set because of the hole configuration, below is a link to one that should work but its not cheap.
AW51 NEW AKAI PDP TELEVISION WALL MOUNT BRACKET PMT4290 NIB AW51 eBay
Feb 23, 2018 | Televison & Video
Removal of base
Most LCD HDTV televisions come with the option to remove the base, refer to your manual for proper instructions on removing the base. But make sure the TV is certified for wall mounting before you do anything - some are not certified and will not be wall mountable.
Sep 07, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
Sharp Aquos LC-65GE1 65 in. HDTV-Ready LCD Television Logo
168 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
