SOURCE: will not take picture
This has happened with 2 of our Stylus 410s. It has to do with the flash not working. If you turn off the flash, the picture will take. I am trying to figure out how to fix the flash portion myself...=)
SOURCE: lcd screen is black
you have to disamled your camera and reconnect the LCD it happens when the cable of the LCD is half out
SOURCE: C8080 acting weired
The mode dial switch, zoom and power are all on the same ribbon cable. If you can spray some electrical contact cleaner into the crease of the mode dial, power button and zoom lever, it may be enough to get thing going again. I would try this with the camera inverted to reduce the spread of the cleaner. The upgrade process takes about 35 seconds. Make a file called firmware on your memory card, download the .bin file into the firmware folder and turn on the camera in play mode. The current version of the firmware will appear and an OK, press "OK" and the firmware will start to update. Do this after a factory reset as you stated that it was stable for 30 minutes. Good luck. Contact me pishta68 at hotmail dot com if you have any questions. I have 2 and a "half" of these cameras. I think the most current firmware is v757-78
SOURCE: Olympus E410 mirror locked up
Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $282.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
SOURCE: The camera will turn on/off But No image on the LCD
For this I would like to know if any water got into the camera.
If it did, then it more than likely has been shorted out, since you said you turned it on.
Good for parts if that is the case.
Any kind water in any camera spells doom.
If you ever have a digital camera which has any water exposure, then immediately remove the battery and if possible open the camera case by removing at least the back's screws, making a note where each goes. Let the camera dry out for a few days minimum.
Even after this, most digital cameras will not survive the water damage. The circuits are so small and delicate that any water will cause damage. Corrosion will do the most damage as a result of water causing chemical reactions with the solder and other elements. Any small damage to these tiny, delicate circuits will spell doom.
is there a way to update furnace?
Is there any way to update the firmware.... I have no idea why I typed furnace
