Question about Olympus Camedia C-8080 Wide Zoom Digital Camera
Card Set Up Error
After owning my 8080 for over a year, it suddenly comes up with the Card Setup screen every time I turn it on.  If I choose Setup, it goes to a Busy bar and gets halfway done and times out.  The camera goes black but does not power off.  It does not give me and option to Not format the card, only format or power off.  I have swapped out cards, swapped out batteries, formatted the cards on my computer and tried again.  I'm stumped.  The cards are read no problem on my computer and I've trasfered all the data from them.  Help?
Thanks very thanks since Canary Islands, i have this problem in the cam by one year, now, the camera is right thanks to u, very very thanks, very very thanks
Posted on Jul 03, 2009
  • 593 Answers
XD or compact flash? If its the xD, format it in a Fuji camera at a camera store (just ask to see a demo and explain to the guy you want to see if the camera will work with that card...) Fuji seems to format cards better than Oly, even the tough ones. If it is compact flash, look inside the socket for any bent pins, common for that type of card.
Posted on Jul 14, 2008
  • Steven Wander
    Steven Wander Jul 15, 2008
    Or you can do a factory reset of the camera. This has cleared up some CF card read errors. Hard reset:
    To do that ,put the camera at the
    "P" setting (top dial) then open
    the card compartment door and press the
    LCD viewer button and the OK button simultaneously till a new menu appears
    with "usb" on top of "Camera". Go into the "Camera" options and
    choose "Reset" and press OK, the camera lens will shift slightly as it
    resets.Then got into the USB option and choose "storage" and press
    OK. Close the battery door, switch off then back on. should be OK if process is successful.
    This is from the C8080 users group on Yahoo which I am a member of.
I need to set up the card on my Olympus C-5060 camera. When I choose the format button, it just beeps forever.
1. Power the camera off and remove and replace the card several times.
2. Recheck.
3. Put in another memory card and check.
If the recheck (2) does help, it may be dirty contacts.
If another memory card has the same issue, the camera needs repair.
Nov 27, 2011 | Olympus Camedia C-5060 Wide Zoom Digital...
I would like to have my CC come on when I mute the TV?
Most TVs today have a program specifically called the "CC on Mute" function. Go to your "Input Setup Program," also called the "On-Screen Display Menu," and choose from the menu the "Setup" function (usually represented by the image of a "wrench"). If your set is capable of this function, then it ought to be located on this page, so simply choose, turn it on, and you ought to be able to have CC with mute each time you choose to turn it on.
May 09, 2010 | Vizio L37 Television
I have a HP xb3000 Notebook expansion base. I have it setup so I can use two screens. It will not allow the other screen to come on. It haves me an error saying no video. I replaced the video cable with a...
Dear conniejo10,
Since your expansion base setup sucesfuly, all you have to do is try to reconfigure your display properties, this is HOW:
Right Click On your Desktop>Choose PROPERTIES on contect menu>
Choose The SETTING tabs, Choose your additional Screen to come on, (it should be position on the '2' Screen when you click on it, the you adjust the resolution by sliding the display control or try to click the ADVANCE/SETTING buton the choose the ADAPTER tabs, the click the LIST ALL MODE button the you choose which resolution that fit your need and match the color mode (better to set to TRUE COLOR).
Then You just hit the apply button. Some hardware need to reboot but some don't.
You should see the two display are now come on at the same time as if you plug the AV out cable in on you expantion base or your Note book.
Good Luck!
Best Regards,
Nov 04, 2009 | HP xb3000 (417329-001) Docking Station
I removed the memory card from my casio exilim ex-z75 while it was still on, and now get "card error" when I turn it on (if it even goes on). I've tried a PNY 2GB SD card, and both a 64MB and a...
Hey! I did this today in my camera, trying to solve another problem (it asks for me to set up date, language and time every time I turn the cam on)... and I got the same error as yours. If you can still turn it on, push MENU while it is on, before the error message appears. And then go to SET UP and choose format card. Then it should work. Good luck!
Jul 30, 2009 | Casio Exilim EX-Z57 Digital Camera
Blue screen access error when viewing or taking pics or vids
Please try to take as many pictures from memory stick as you can then format memory stick through format option in setup.
Hope this will resolve this blue access issue.
You can use another memory stick like 1GB in this camera.
Mar 13, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
All of a sudden, with no obvious cause, my computer will crash and up will come a black screen with white text. The only thing that seems out of the ordinary in that text - to my layman's eye - is the...
The only time I've seen this error in the past, it turned out to be a memory error. Try replacing the Ram with new DIMM modules. If possible borrow some from a friend or another PC that you own to test this theory before spending money on it.
In the other case the person had One DIMM and two slots. When he put a DIMM in the the 2nd slot it resolved his problem.
My guess is that the Board is setup to use memory in dual channel mode only and develops a chcksum error if the memory slots are not filled in pairs. It is also advisable to fill them with Matched pairs (Meaning that they are from the same manufacturer, have the same timings, and if possible are from the same lot)
Hope this helps you
Nov 26, 2008 | Intel Motherboard
Olympus 8080 C 8080 wide zoom
It may have jumped a tooth, something like a car timing chain. The Zoom in this camera is a barrel that has 3 cams that rides inside another barrel that has "tracks" for the cams. The motor rotates the the outer barrel via gear teeth, forcing the inner barrel to extend or retract. There is a tab on the gear teeth that might index the position of the zoom lens. If this tab is in the wrong position, if the gear jumped a few teeth, the camera may not know where the zoom lens is in relation to the inner focusing lens, and cause the "zoom error" If that is the case, I can help you get it back into position. This is a theory, but does explain the tab on the gear and the constant zooming.
May 27, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Set date and time comes up every time i turn on camera
Try resetting your camera. In picture taking mode press menu. Go to setup, go up to reset, press right arrow, make sure reset is highlighted and press set.
Then TAKE OUT MEMORY CARD. Go back into menu, go to setup, go up to format, press right arrow and highlight format, press set. Input ur date and time again and then power off and back on. If that doesn't help then you have to send into repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Feb 11, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Olympus C-8080 LCD wont work
Is the battery setting set to Battery Save mode. If it is then the view screen does not work.
Apr 07, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Card Error?
i think you have broken or bended any of the pin inside the card slot, and that is creating problem. Try looking in the card slot you may find any of the connector pin broken or bended. Try straighten the pin cautiously and may your machine start working .
Aug 16, 2006 | Fuji FinePix S7000 Digital Camera
Olympus Camedia C-8080 Wide Zoom Digital Camera Logo
159 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
