Question about Metz Cameras
Metz 44AF-4C ready light does not come on,has new batteries, all functions work?
Has not been turn on for a while
    New Friend:
  • 30 Answers
The energy for the very short, very high brightness flash is held in the flash capacitor of the photo flash lamp. This capacitor degrades if is not charged for long (years), and needs formatting, which is a slow charging and 2-3 consecutive shots. Sometime the first charging takes significantly longer than normal time, even minutes. If however the ready lamp does not come up even after some minutes, the flash lamp may have developed an internal fault, which can only fixed by a trained repairman. Another common culprit is wrong contact in the battery compartment. Batteries left in the flash for long often leak, and corrode the contact springs and leaves. These can be cleaned with soaked with vinegar cotton tabs (ear cleaning buds), followed by mechanical cleaning with pencil eraser.
Posted on Mar 01, 2014
2 Suggested Answers
SOURCE:
  • 261 Answers
SOURCE: Metz 76-56 battery charger keeps flashing red light
One of your cells is defective.
It maybe brand new, but we don't know how long it's been in the box.
You will need a DVM to troubleshoot the battery.
atdlee@netzero.com
Posted on Oct 04, 2012
Metz 44AF-4C ready light will not come on or flash,all others functions work
If the unit will flash at all then you may be able to "re-condition" the capacitors or condensers. If so, then make sure you have a fresh set of batteries and trigger the flash in manual mode full light. As the capacitors heal and are able to hold more energy the light output will increase. If you are able to recover them then the voltage level will increase to where the light comes on. Otherwise they likely need replacing and this is work best left to a technician. This work is also expensive so you need to decide if it is worth it or simply replace the unit. Good luck.
Feb 24, 2014 | Metz Mz 54434c 44af-4c Flash For Canon...
How to dismantel metz 44af-1 flash?
You would need small Star & Hex Screwdrivers.
Oct 09, 2013 | Metz Cameras
atdlee@netzero.com
Oct 04, 2012 | Metz NiMH Battery 76-56 for 76 MZ-5...
Shift key isn't working properly it is backspace how do i fix this problem
this has been a problem with my "internet navigator logitech keyboard" and when i run the "#keyhistory" script i get these results after hitting
the following keys :
L L RightShift L L CapsLock L L
VK SC Type Up/Dn Elapsed Key Window
4C 026 d 0.47 L
4C 026 u 0.16 L
4C 026 d 2.89 L
4C 026 u 0.17 L
A1 136 d 2.19 RShift
A6 16A a d 0.02 Browser_Back
A1 136 u 0.16 RShift
A6 16A a u 0.00 Browser_Back
4C 026 d 0.80 L
4C 026 u 0.13 L
4C 026 d 2.52 L
4C 026 u 0.14 L
14 03A d 6.05 Caps Lock
AA 165 a d 0.02 Browser_Search
14 03A u 0.19 Caps Lock
AA 165 a u 0.00 Browser_Search
4C 026 d 4.80 L
4C 026 u 0.14 L
4C 026 d 0.11 L
4C 026 u 0.14 L
and as you can see I have two problems with this. One problem is that when i am in an internet browser and i hit shift it acts as Backspace/Back and when i am renaming a folder and i hit shift to use caps it also acts as Back. The other problem is similar with the Caps Lock key, whenever i am in an internet browser and i hit Capslock, the Search window appears and the Capslock function gets activated as well.
I was trying to Remap these two keys but i wasn't successful in doing so,
for the shift key i tried remaping 00_6A and E0_6A to another key and i also tried remapping 00_36 to another key and neither of these two helped.
and for Caps lock i tried remapping E0_65 to another key and it didn't work. I also tried turning off both the shif key and the CapsLook key and their that only turned off their original function but it didn't turn off the backspace or the search functions.
Aug 16, 2010 | Computers & Internet
Metz 58 AF with Nikon d90 wont flash
Hi, Bad news for you.
Try this.
  1. put new batteries in flash.
  2. turn flash on off camera.
  3. listen for capacitor to squeal (high pitched whistle). If you hear it it is charging. If not capacitor is bad.
  4. Also should see flash ready light come on. If it does not same as #3 above.
  5. If you pass #3 & 4# above press manual flash/check/test button on flash. No flash means bulb is out. It can be replaced.
Hope this fixed ya. Please rate. Good Luck! Comment back if you need further assistance.
Mar 14, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Cannot fire off cameta
If the Metz 44 is older then 3 years, than it's an software problem. I Had the same with the Metz 44AF-C and my EOS 30D. The same metz works well with mij Rebel (300D)
Tweety
Jun 08, 2008 | Metz 44 AF-4 for Canon TTL Flash
Metz 58 - broken
Take out batteries
Put in 4 new Energizer Lit. Bat in.
Turn on flash
Wait for the ready ready, fully charged
Press the test button out.
Flash should be able to be fired.
atdlee@netzero.com
Aug 13, 2007 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Metz 60-4 flash takes much longer than normal for the ready light to come on to allow me to take another photo.
It is likely the capacitor in the battery pack. If they are not powered up every month, they dry out resulting in long power up and recycle times. You'll need to get it replaced to rejuvenate your 60 CT-4 to its original spec.
Oct 06, 2006 | Metz 60CT-1 Flash
Cameras Logo
132 people viewed this question
Top Metz Cameras Experts
Doberman
TimHu
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Metz Camera Expert? Answer questions, earn points and help others
