Question about Black & Decker (CBM205S) Electric Grinder
CBM205S - Black & Decker Coffee Grinder
I put in the beans on top, then nothing, the on off button doesn't work at all.
  • Anonymous Mar 26, 2008
    I have only ground 3 cups of coffee and all of the sudden it does not work when I press the button. Everything is secure, but nothing happens... not even a sound.
Make sure the top cover is depresed fully. There's a safety switch underneath it.
Posted on Nov 11, 2007
How do I dismatle the grinder on my Krups espresseria automatic
I suspect that as you have only managed to remove 2 screws from the beans container that this is going to be quite a task for you but here goes.
1) Remove the button from grinder adjustment by pulling or levering upwards
2) Lift beans container off
3) Remove front trim panel (square frame like a picture frame at front) Done by removing drip dray and thumping frame upwards with heel of your hand.
4) Undo 2 outer screws at top front of top housing
5) Undo screw in middle at back under where beans container was
6) Lift off top housing, you may need to rock & flex it a bit to release rear clips
7) Put knob back in & turn grinder adjustment fully right (clockwise)
8) You now need to mark that part of the grinder top that goes between knob and grinder so that you will be able to put it on exactly as it is now. Then remove that part from the top of the grinder
9) Now you can turn the top of the grinder anti clockwise further than the adjustment knob was moving it.
10) Once you have turned it as far as it will go you will be able to lift (with wriggling) the top part of the grinder out.
11) Cleaning out will be done with a small screwdriver and vacuum cleaner with nosey parker attachment fitted.
Dec 29, 2014 | Krups Coffee Makers & Espresso Machines
Why does ground coffee not go thru shoot
If using Beans; it is set to fine and due to static it sticks - OR you have a blockage..
If you are putting ground coffee into a grinder; the static will be a bigger issue and in addition there is no weight from the beans to press the grinds into the burrs. A bean grinder is not ment to grind beans that have already been ground.
Get a better grinder and do not buy supermarket beans.
May 31, 2014 | Capresso 560.01 Infinity Burr Grinder,...
How to cook pinto beans in my 22 quart roaster oven
I cook 140 lbs of beans every year at church for a ham & bean dinner. I soak them overnight in 4 large rubbermaid containers (about 35 lbs in each covered all the way to the top with cold water). In the morning I drain the water, rinse beans and divide between about 14 cookers (several of them are the 22 qt roasters). You can put beans in to about 1 1/2 to 2" of the top rim. Put a ham bone in (I pre-cook about 12 10 lb bone-in hams two to a roaster sitting in about 1" water several days before, chop the meat, save the juice and the bones) and a cupped palm full of salt (3/4 to 1 T ?) and cover with water. Cook on about 350 degrees. When they start going dry add the leftover ham drippings that were saved (I usually have it heating in a crockpot nearby so that it doesn't slow the cooking of the beans down).
Aug 10, 2011 | Rival 18 Qt Roaster Oven with Buffet...
After cleaning my machine I am left with the classic one extra part when reassembling. The part is a black rubber ring, a little less then 2" around, one end has 4 slits. I think it may fit over the...
HI
It fits on top of the grinder and under the bean hopper. There are 4 ridges on the grinder that it fits on and seals the grinder to the bean hopper. Just remove the bean hopper and put the rubber piece on the top of the grinder.
May 09, 2011 | Saeco Vienna SuperAutomatica Coffee...
How do I take my Imressa E8 apart?
Remove water container and empty beans. BE SURE UNIT IS UNPLUGGED.First, facing the unit, take out the three black torx screws from the bottom front. It makes removing the sides a little easier. Next, open the top lids, beans and water, and find the black pan screws in the top front and remove. Now, facing the rear of the maker, there are four screws disguised as buttons. Clamp on to the steel with a linesman pliers or you may need a side cutters. If using a side cutters, apply just enough pressure to grip and not cut. Remove screws counterclockwise. The top cover should lift up at this time. The side panels slide back to unhook from bottom and must be manipulated to release from front face. The side panel nearest bean grinder seems to remove a little easier than the water side. At this point, you may be able to clean bean grinder chute without further disassembly. If you need to service bean grinder, right side panel needs to be removed. Then remove the stainless torx screw holding on the bean cover to the grinding chamber. Adjust knob to full coarse setting. Next, find the two black torx screws inset in the bean container, probably have beans stuck above them. Remove bin. Do NOT remove the stainless torx screw on the top of grinder worm (on top of grinder blade)! From the side of unit, make note of clear and black wires on bottom of grinder motor so that wires will be put back on same terminals (can't remember if it was a dc motor). Remove wires. Make a mark on gear teeth of fine/coarse gear and gear ring of grinder to retain calibration. Now remove three stainless torx screws holding in grinder ***'y. Grinder ***'y should come out. Cleaning is easier at point. If you are to go further into the disassembly of the grinder, care should be taken because there are small springs and ball bearings in the ring gear and cutter.
Dec 26, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
My delonghi esam5500 coffee bean grinder part is not working. seems to be blocked, can see beans moving when it goes to grind but no beans are taken in and it comes up with fill beans compartment? what...
In our case we were lucky. Grinder was blocked by the beans. This is what I have done with our Delonghi 5400. It looked fiddly but was quite simple really. I started from the back panel. Once back panel was removed I had access to 4 corner screws that remove both side panels. Now that give me access to 4 corner screws that hold top of the machine. I l also had to unscrew 5 screws that hold coffee container in place. 4 are visible once the coffee beans container is open, but the 5th is hidden in the middle of adjustment arm with a black cap on top.(adjusting how fine you grind). I used small sharp screwdriver to lift the cap. Once all are out I removed the top of the machine and then the funnely coffee container too. That exposed grinder assembly. Top of the grinder is actually loosely sitting in the lower part of grinder. Twisting it counter clock should release it I Think. Our was not budging, and I had to completely remove the grinder and detach motor but that is quite obvious too, and probably not needed. I just wasn't sure what I was doing. Our machine was out of warranty so... Would be nice if we had some schematics.
Nov 26, 2010 | DeLonghi Perfecta ESAM5500 Fully Automatic...
I put beans in where the grinds should go. help!?
Hi
Open the door and remove the drip tray. Then remove the brew unit and empty the beans. Make sure that you get all the beans. Check the brew unit thoroughly. Then put everything back. Try the pre ground button but don't put anything in the brew unit then push the medium coffee button. That will run the machine through a brew cycle and if it works OK then you set to go.
Dec 30, 2009 | Saeco Incanto Classic Espresso Machine
Black & Decker (CBM205S) Electric Grinder Logo
220 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Lyle Siemens
Lyle Siemens
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
