Depends which wireless headphones you have. Most headphones do not use WiFi, they use Bluetooth or 2.4 MHz RF. Usually a wireless headphone set will have a transmitter plus the headphones. The transmitter usually connects to the TV either with the analog L+R ouputs or the stereo headphone jack.
Try plugging it in to the charger for a while. That sometimes works. Also, if it got any moisture in it, you may have a short causing the power to remain on.
1) Tap the "Menu" key on your Ally, this is the hard button with the lines. 2) Tap "Settings" 3) Tap "Wireless & network settings" 4) Ensure that there is a green check mark in the box next to "Bluetooth." 5) Tap "Bluetooth Settings" to configure your connection, you can set your device name, make your phone discoverable, and search for other devices.
Tool; CSR bluetooth dongle 2.0, got from store for only $2.50. Install Toshiba Bluetooth
stack v7.00.10(T) driver Win7x64 (search in google to download the
installer). from
OFF state of your BH-214, press power button until LED flashes
quickly,do not release the button, stay press until LED
flashes red & blue alternately slowly.On ur PC,->Add new device,
then your PC would detect BH-214 as headset. Work fine with my BH-214 to connect with PC through BTooth dongle (A2DP 1.2
(btooth audio profile) & AVRCP (player navigation control profile))
& at the same time with my phone (HFP, HandsFree profile).
my vauxhall insignia sri wont sync the bluetooth to my phone.....when i press the CONFIG button & select phone settings it says not available, I have the CD 300 & my phone is a samsung Galaxy S I9000
with the headset off, press & hold the power button for about 9 seconds until the indicator light alternately blinks red and blue. Set your phone to search for a new headset or bluetooth device. When it finds the headset, the passcode shoudl be 0000
Make sure you put the bluetooth in discovery mode, otherwise the phone wont be able to find it. I have a plantronics bluetooth and my env2 works just fine with it. Good luck.
ok goto bluetooth setup in blackberry
when it starts search hold bluetooth power button on this will sync the 2 together at the end it will ask for a pin
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done
