Question about Brookstone Pure-Ion UV Air Purifier
PURE Ion shuts off after a few moments
When I plug in my PURE ION it only stays on for a few mins and then I hear a beep and it shuts off is there a way to reboot or reset this machine?
  • 1 more comment
  • dsmith4882 Nov 26, 2007
    I cleaned the filters and it will not turn on.
  • mamakass Mar 10, 2008
    I have replaced this machine 3 times. This one has worked the longest.
    The program set button got pushed, I could not turn it off, so I unpluged it and now it will not come back on?  I have unpluged and replugged? What now?
  • Anonymous May 30, 2008
This machine is less than 2 years old and I paid $500 for it. I am extreamly disappointed. Broostone was no help at all. How do I get it to work again. It was on then I tried to turnit off and it would not. I un-plug it instead it would not turn on since. Additionally, I wash the filter, vacuum it and put the filter back on at the same time. It still would not work. Please help.
Posted on May 03, 2008
i had this happen and i clean the filters thoughly then pushed the power button and nothing, then i started running my fingers over the touch screen and almost magically  it came o....
Posted on Apr 18, 2008
You need to shut it off, unplug it, and pull both the filters out at once and then plug it back in, and push both filters in at the same time, simultaneously. This will re-set it.
Also, if this continues to happen, you must vacuum the insides of the unit, aside from the filters, themselves, it can get all clogged up.
We live on a busy street and our house can get REALLY dusty, we have a older home with carpets and two cats - so our unit really has to work hard!
Posted on Mar 21, 2008
How do i clean my Brookstone Pure-Ion Uv Air Purifier
[PDF]Pure-Ion® Pro - Brookstone
BrookstonePure-Ion® Pro. Air .... Use this unit only for its intended use as described in thismanual . 4 . .... Position the unit so the cleaner air flows to your desired location .
Aug 30, 2015 | Brookstone Pure-Ion UV Air Purifier
Try leaving it unplugged for a while to reset it.
Jul 23, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Were to buy small fan units for Brookstone Pure Ion Pro?
The Best place I have found that has quite a few at reasonable prices plus knowledgable store personell that will guide you to what your needs are..and their warenty policy at Lowes excellent....give them a try and good luck.
Sep 18, 2014 | Brookstone Pure-ion Pro Air Cleaner
Filters are clean, soft cloth used to wipe inside of each filter slot down...not so much worried about the constant clicking, as much as I am the unit running 5mins and shutting off, or the alarm sounding...
These are usually quiet so the clicking might be an problem. It could just be a dirty ion generator. On this unit you can toss those into the dishwasher. If they are dirty enough the click you hear might just be a spark. If it is sensing this it might be why it is shutting down as well.
I've included a link to the manual for the unit so that might help you out in settings and so on.
This is the pdf manual
This is a link to the product page, at the bottom is the tab for warranty and manuals.'SubCategoryWidget'630285p&catId=L3_AirCleaners'L2_HomeComfort'L1_Home
I would download and read the manual, clean the unit according to the manual and see if that makes it behave. When these work they are incredible at what they take out of the air. We used a commercial version of this unit in a 13000 sqr foot room and even with a few hundred people who smoked (was allowed at the time) the air remained clear. The ion traps were revolting disgusting when they were cleaned once a week so they definitely pull stuff out of the air.
Sep 12, 2011 | Brookstone Pure-Ion (506840) Air Purifier
My brookstone pure-ion air purifier is stuck in the run program mode and will noy shut off how do i reset it
If you or someone needs helps on fixing this problem of the Brookstone air purifier, please send me an email at
Dec 20, 2009 | Brookstone Pure-Ion (506840) Air Purifier
Cleaning tips for my Brookstone Pure Ion
I have Bridge Stone Ionic Air Cleaner and I cant figure out how to take it a part to clean the filter. It's a few years old, used very little and I don't have a manual. Can anyone help. thanks
Nov 06, 2009 | Brookstone Pure-Ion UV Air Purifier
Pure Ion will not turn on. We took out the filters to clean them. Wall outlet works for other items. Have tried other outlets.
It sounds like the main board is not getting power. The power supplies have capacitors inside that do overheat and burn out. You can test power coming from power supply leading to main board with a voltmeter. You can try to unplug for 8 hours, in meantime while unplugged, press and hold power button for 5 seconds, then wait 1/2 hour and plug back in to see if unit has reset itself
Oct 13, 2009 | Brookstone Pure-Ion UV Air Purifier
Snap and no power
I beleive your unit is overheating. this maybe due to build up on the air intake -rear of unit etc.
If there is no way to clean filters you may have to manually take it apart and remove dirt
Aug 12, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Brookstone Pure-Ion Air Purifier
Try this link. This is for the older version. Also check Brookstone's customer service heading "product manuals".
Feb 23, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Brookstone Pure-Ion UV Air Purifier Logo
321 people viewed this question
Top Brookstone Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Brookstone Air Purifier Expert? Answer questions, earn points and help others
