Question about Zenith IQB50M90W 50" Rear Projection Television
Red and blue light ajust but green one will not
I can ajust the red and blue light using the cross hairs in the projector set up  but the green also needs ajusting please help
  • 50 Answers
Believe you would have a open resistor on the green crt board, was either a 120k or 110k resistor
Posted on Nov 20, 2007
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
Im seeing duble words,how can i fix it?
There should be a convergence adjustment on this set. It will have a "cross hair" type pattern
You adjust the beams so that the cross hairs turn white. I believe Green is not adjustable intentionally. The procedure is to adjust the vertical Red line until it alligns with the Green line. Then adjust the vertical Blue line until it lines up with the Red and Green. The line should turn White.
Repeat the procedure for the horizontal lines. When you return to regular viewing mode the double
images should be greatly reduced or eliminated..
Hope I've helped you,
Best Regards,
Mark
Dec 30, 2010 | Panasonic Televison & Video
Does it take some type of gel under the lights, the colors are a little blurry
i also have this tv. i removed backcleaned mirrior, back of screen and lenses VERY GOOD. Then turned on tv go to convergence, sepaerate cross hairs then adjust focus on lenses. Then lenses rotate maybe about a 1/3 turn total by hand. Grab ring that houses lenses and turn until cross hairs are as clear as possible. This can be done with out help by watching inside of screen. red and green are adjustable, the blue is adjustablealso but i couldnt find blue cross hairs, maybe by covering red and green lenses the blue will show on screen. anyway when done and cross hairs are clear,lenses, mirror and screen are clean, you can adjust covergence and get a very clear screencleaning will also brighten pic. Pete
Mar 27, 2010 | Philips Magnavox 9P6034C 60" Rear...
Picture is OK, but colors are off and there is a blue star background that shows on dark colors.
Hello, With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one. If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
Oct 26, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Convergence line will not move to match cross hairs
the green line will not move. it is stationery and red and blue have to adjusted to it
Jul 20, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Works but prdominantly green, can't ajust with color controls
The lcd polerizer(not sure this is proper name ) is bad.It has three: red,green,blue and one of them is bad. I also have a similar issue but only on the left side. Took it apart and found the bad one.
Mar 07, 2009 | Sharp Notevision XG-NV6XU Multimedia...
Cross hairs
Hello, You need 2 convergence ICs if you cannot converge the red and blue lines on top of the green "cross hair". You should be able to use the front panel controls to move the red and blue around. If you can move them around and they just won't move completely on top of the green then the ICs are bad. The ICs are mounted to large,finned heatsinks and have numbers that start with "STK-" and have numbers following. These parts are available from http:\\www.tritronicsinc.com.
Dec 01, 2008 | Toshiba 42H83 42" Rear Projection...
Center adjust on Red gun is not aligning with B&G vert.
frist set blue and green than set red itwill shoew yu single chakall will be focous in single line than than gun will be allign horizontal if it will correct if itisnot comming than cathode problem.
Oct 06, 2007 | Sony VPH D50HTU Multimedia Projector
Convergence
you have bad convergence ics
Apr 13, 2007 | Toshiba TP61H60 61" Rear Projection...
Zenith IQB50M90W 50" Rear Projection Television Logo
75 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
