Question about Mitsubishi VS-50805 50" Rear Projection Television
Picture jumps until tv warms up. It is taking a longer time for the jumping to stop. Can you please inform me what is causing this problem 50Mittv in SA
Leaky electrolytics around the vertical drive circuitry and/or on the powersupply B+
Posted on Mar 27, 2009
Picture is jumping lg55lb7500
10 Ways To Fix A TV Picture That Jumps Jerks or Skips ...
https://removeandreplace.com/.../10-ways-to-fix-a-tv-picture-that-jumps-jerks-or-skip...
Aug 5, 2016 - QUESTION: When I watch my TV, the picture sometimes jumps. How do I test it to see if it's the TV or another issue? If your TV picture is jumping while watching cable, satellite, or streaming, there are a few things you can check. See below for the best solutions to fix a TV where the picture seems to "jump" or ... Missing: lg55lb7500
Picture jumps every few seconds. - Forums - CNET
https://www.cnet.com/forums/discussions/picture-jumps-every-few-seconds-375282/ Dec 26, 2009 - 5 posts - ‎2 authors
I have a Samsung LN -T4061F model I bought two years ago. Over the past two days I have noticed that the TV picture jumps every few seconds. In the trouble sho... Picture Issue on my Samsung Television/Blu-Ray
23 Aug 2010
Samsung UN55C8000 Jumping images
7 Apr 2010
More results from www.cnet.com
Missing: lg55lb7500
How to Stop Jitter on a LCD TV ' Techwalla.com
https://www.techwalla.com/articles/how-to-stop-jitter-on-a-lcd-tv Mar 31, 2015 - When using an LCD television you may notice occasionally that the picture jitters, or jumps down the screen. This makes watching the set rather disorienting and may even cause headaches. Fortunately, there are a few troubleshooting steps you can take to correct the jittery picture issue before calling on a ... Missing: lg55lb7500
Picture jumping - The eBay Community
https://community.ebay.com/t5/Technical-Issues/Picture-jumping/td-p/26963824 In the last few days, when I have been viewing photos/pictures in a seller's listing, they have been flickering and jumping until I viewed the.Missing: lg55lb7500
Feb 21, 2018 | Televison & Video
Tv picture rolling vertically
Vertical oscillator and output section should be trouble shooted. It is a skilled job.
Mar 09, 2012 | Zenith Televison & Video
My picture started out jumping horizontally and after it warmed up it would work fine. now it is jumping vertically and doesnt stop jumping.
The reason your TV is doing this is due to a component that has become thermally sensitive, & when it heated up it made better contact, and, as it has thermally cycled, hot to cold to hot to cold again over and over the compnent has failed completely, thus the fault is as we say :Hard On".Which is easier to diagnose than an intermittent thermal problem. The only real fix is to take it to a ruputable service centre/man and get a firm "Quote" for reoair.
Jan 20, 2010 | Mitsubishi VS-4543 45" TV
Picture jumps on projection tv
There is not more knobs for V hold so there is a circuit in its place that is going out and needs repaired and it is worth it because these TV are great when they are fixed it will get worse do not bang on it your going to loosen the part that is going out and may cause it to heat up and the list goes on.. take it in you be glad you did if this info helps please rate it fixya thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 26, 2009 | Hitachi 53SWX10B 53" Rear Projection...
Zenith tv picture jumps after 20-30 min.
the variations of the supply causes that. a verticle stability be checked, specially semiconductors and capacitor changing valuas
Q= CV
Q=IT
THEREFORE
IT=CV=Q AND frequincy = f=i/t
so if I AND T CHANGES CAUSING MOVEMENT OF PICTURE
SO I is for time and T for tempareture
Mar 28, 2009 | Zenith B25A02Z TV
High idle/low idle pattern
This issue is caused by the egr valve being stuck open, more than likely. Just remove it and clean the plunger on it. Also clean out the two ports that are in the intake. Check out saturnfans.com for more information. I hope this helps.
Dec 08, 2008 | 1997 Saturn SL
60 inch philips magnavox
When you first turn on the tv, It goes from small picture to full screen and several corors around screen for a few minutes,I guess until it warms up? Could you please help? Thanks!
Mar 25, 2007 | Philips Magnavox 9P6034C 60" Rear...
Mitsubishi rear projection tv
I've worked on a few of these sets and have found C2P08 to cause something like rolling bars in the picture and have found C2P05 to cause lines jumping in the picture.
Feb 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
4 yr old Toshiba jumps when turned on
take it to a tech if you have not done so. your problem is lose solder.your board needs to be rsoldered over to connect your component properly over the years heat from the operation of the tv cause the soldr to lose grip on the board.good luck
Jan 07, 2007 | Toshiba 36HF72 36" TV
Mitsubishi VS-50805 50" Rear Projection Television Logo
111 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
