Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Akai lct42z6tm
By doradave1 on Oct 28, 2007
my akai 42 inch flat screen has 4 scrambled squares (1 in each corner of
screen) when i try to use a hdmi channel.If i cut the unit off and switch to
a non hd channel all is fine.Funny thing is it worked fine for a while. I have
a cox hdmi converter box with a phillips 12 foot cable going to tv. Should i
try dvi/hdmi rather than hdmi/hdmi cable? Thanks
Same Problem
Mar 19, 2009
-   I finally got SAM's club to take the 42" Akai TV back. They gave me full credit, so I bought a Vizio 47" 120Hz for less money than I paid for the Akai. You just need to find the right person at SAMS Club to solve the problem. -   maseratijim
Jan 20, 2009
-   I had the same problem described by other owners here. Just for the heck of it, I pulled the power cord out of the wall, leaving the set totally without power, for about a month. Plugged it back in, turned the set on last week and... problem solved, great picture. Don't know if this is a permanent fix (I'm not an engineer) but it might be worth a try before you plunge into repairs. When not in use, I keep the set unplugged.-   jackwol
Oct 02, 2008
-   I bought my Tv 2/2007 and switched tioDirect TV HD...my resolution are spotty on 720 and 1080...i thought it was the reciever, but now reading all of the comments here I'm thinking has changed. Direct TV tech said it was my TV,,,I am going to insist SAM club take this TV back and exchanged. I paid too much money for the TV not to give me HD clarity. I have been paying for HD as well. Sound like We have a lemon here. I had this problem from the onset...an all thi time thought I was getting bad service from receiver. my product is LCT42Z6TM
-   lbvinson
Sep 23, 2008
-   I have the same problem. Bought it at SAMS in April 2007. Will try to get it fixed uner the Mastercard "double factory warranty" program. THanks for letting me know what the problem is.-   maseratijim
Sep 17, 2008
-   i have the same problem...but I replaced the 4 capacitors mentioned and it STILL doesn't work. I still get those four squares and the white lines. What else could be the problem? -   raytheonlisz
Best Solution
posted on Nov 05, 2008
Very Helpful)
paronidi
Rank: Apprentice
Rating: 100%, 1 votes
Thanks for the suggestions! I replaced the capcitors and now the TV woeks like a champ!
Was this helpful?
Yes
No
Solution #2
posted on Oct 11, 2008
Very Helpful)
ort11
Rank: Master
Rating: 98%, 13 votes
Yes, I am a computer / electronics person and by brother's tv had the same problem, here is a complete description of the problem and the fix. Many thanks to all that have come before
Symptoms
1) While watching tv, there will be vertical grayish lines that move around a bit on the screen
2) While viewing a menu, the menu will be all hacked up as if the bits are all out of order
3) If you unplug all of the sources and then re-power the tv, unplug from wall, the tv will seem it is working fine. Menus will work until a video source (Component) is plugged into the tv.
Tacking the back off
WITH TWO PEOPLE Lay the TV on a table with a blanket, etc to protect the tv. Do not try and move the TV with the back off in general. You may flex the screen and damage it.
Remove all of the screws from the back including the one under the sticker near the left bottom. Remove the stand from the bottom. Lift the back up from the left to the right. Power is hooked to the right of the back. Remove the two screws to remove the power jack from the back.
Remove the back and place aside
Remove the RF cover from and the board will be underneath
Remove all of the screws from the board and from the RCA connectors from the outside bottom of the board.
Carefully remove all of the wires, taking time to remove the glue from the connectors. The glue should "Snap Off", take your time here. Remove the wires, noting where they all are. Take your time with the big connector on the left side.
You will see that all / some of the caps will have a discoloration on the bottom.
Replace and replace ALL of the caps on the upper left side of the board. It's OK to replace with a higher value Voltage, they must be the same uf value of equal or higher voltage. They must be electrolytic caps (+/-). Make sure the line up the - properly with replacing. Radio shack may not have all of the them, but other electronics supply place should. They are call fairly common.
If you have never done this before, find someone that has, or find another tutorial on how to do this. You will need a small soldering iron and solder ****** and very thin solder from Radio Shack.
Replace the board, we tested by putting the board back. Sliding the TV on a table so the top could be seen and then plugging a source in and verifying it worked before reassembly. You HAVE to have a component source plugged in or it will false positive the test. We found this out the hard way....
Replace the back and the screws. On the right side of the TV MAKE SURE that the AC power wires are NOT in the way the screws on the right hand side.
Replace the TV to the original position and test....
Reason for Problem.
Either they have a flaw in the design, but more probably they had a poor supplier of the Capacitors. I have seen this before and we will probably see it again. This really should be some sort of class action suit since they are all failing about 1.5 years of use.
Any question, please contact me....
orthober@msoe.edu
Jeff Orthober, Assistant Professor, Milwaukee School of Engineering.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
Very Helpful)
Guest
Rank: Apprentice  Televisions & Videos  Expert
Rating: 0%, 0 votes
Symptoms
Reason for Problem.
orthober@msoe.edu
Solution #4
posted on Mar 31, 2008
Very Helpful)
zhopa
Rank: Apprentice
Changed the capacitors C280, C302, C320, C323 - 100UF 35 VOLTS. Bought em at Radio Shack $5. Took about 2 hours cause I'm slow. Capacitors are in a group on the board with all the AV connections.
Works Great
Was this helpful?
Yes
No
Solution #5
posted on Nov 19, 2007
Very Helpful)
rickhunt
Rank: Apprentice
Rating: 100%, 5 votes
Dont feel too bad..i bought 3 of these LCT42Z6TM monitors. They all developed the same problem.(scrambled video) They started displaying garbage on the screen. My guess is a bad AV board. Contact AKAI. theres an 800 number that came with the setup instructions. they didnt jerk me around. they told me to take the unit back since it was less than 30 days old. they will come to your house and fix it if you like..dont let time slip by doing nothing..call AKAI ...rick
Was this helpful?
Yes
No
Solution #6
posted on Mar 06, 2008
Very Helpful)
scott10
Rank: Apprentice
Rating: 98%, 4 votes
Replace the capacitors at location numbers C280, C302, C320, C323 - 100UF 35 VOLTS.
This does work. My TV was scrap and then 59c and 1hr of work later it's like brand new again.
However I used 100UF 50V electrolytic capacitors. No difference, just a higher max voltage rating.
Was this helpful?
Yes
No
Solution #7
posted on Jul 14, 2008
Helpful)
bobbyd1616
Rank: Apprentice
Rating: 92%, 5 votes
I can confirm that replacing these 4 capacitors worked perfectly. I work in construction so i am not a technician or anything. I did not even have a solder iron. I have photos of the board if anyone would like to see them. Took me about a hour to replace the 4. I had to use (2)35volt & (2)50volt cause radio shack only had 2 of each and it works like a charm. This TV has been in storage for 6 months until i found this article on the problem. Cant say thanks enough!!!!!!!!!!
Was this helpful?
Yes
No
Solution #8
posted on Dec 27, 2007
Helpful)
david-dxh
Rank: Guide
Rating: 87%, 26 votes
tech support at akai says: "AKAI model LCT42Z6TM - If there is no image or a badly distorted image with horizontal static lines, usually with four boxes in all four corners of the screen, there is a possible fix for this. There are four capacitors on the main board that have been identified as the primary cause of this symptom. Replace the capacitors at location numbers C280, C302, C320, C323 - 100UF 35 VOLTS" - this works - [dxh]
Was this helpful?
Yes
No
Solution #9
posted on Sep 05, 2009
Not Rated)
3Olives
Rank: Apprentice
Rating: 0%, 0 votes
OMG Thank you for the capacitor fix. My Akai has been in storage for a year and I finally came across this capacitor fix. I went to Radio Shack and in 30 min I was back up and running. Thank you thank you thank you
Was this helpful?
Yes
No
Solution #10
posted on Mar 19, 2009
Not Rated)
wolfgang600
Rank: Apprentice
Rating: 0%, 0 votes
you guys are awsome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
it worked great like brand new ....
the funny thing is just pucked it for a barter (next to nothing) ,spent five bucks on capacitors and got a large LCD
again thank you
Was this helpful?
Yes
No
Solution #11
posted on Jul 27, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
I just did the same thing with a return i bought from SAMs Club for $398. It does work and the TV''s HDMI and Component inputs work absolutly fine. The 100 mf Capacitors are $1.59 each at Radio Shack and I was able to replace them in under an hour.
Thanks
Solution #12
posted on Jan 21, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
I have been trying for four months for Akai to fix this very problem. I live in the Cleveland area and they claim that they are trying to get a technician but can't find one yet. Give them 10 to 14 days and call again is the constant refrain. At what point do I just take it back to the store for a refund. I understand that it is an easy fix so don't want to do this if it can be avoided. I've been paying for HD and am getting a crapy picture for my money all because of a faulty TV. Needless to say, I will never buy an Akai product again.
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
Good quality flat screen TV in China
Answer
Looking 65 LCD pls give us your view
Answer
I need to replace my akai model lct3201ad circuit board, it looks like some of the compacitor have... (More)
Answer
got a fog on screen,small area looks like smoke any way to remove it Thanks Hal
9 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Aug 22, 2008
same problem...set is 14 months old.
Comment by Brucemitchel, posted on Aug 16, 2008
Thank you, thank you, thank you! I tried the fix described here. I am no expert and the soldering was a bit tricky for me since my iron was just to big and my hands a bit shaky. But I am all done and the set works great. Many thanks to fellow who posted the picture i could not see those numbers for the life of me. I bought my set at Sam's from the "broke pile" for $400.00. Thought the problem was the cable at first, and screwed around to long to return the set to Sam's. I called and wrote Akai and received no response. I will not buy anything again that says Akai. My screen was completely gone before this repair. Just multicolored lines that would pop up after a minute of cycling through the power. I REALLY appreciate the help I received here.
Comment by Guest, posted on Dec 03, 2007
I have the same problem with my Akai LCT42Z6TM, but when the unit finally warms up (about 10 minutes), the HD Channels work great !!
Comment by yyyy, posted on Nov 27, 2007
same thing scrambled squares in all 4 corner's display also scrambled and when i do get a picture in hd little white lines running across the screen. got to keep turning it on and off to get a picture
Describe your Flat Panel Televisions problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
