Question about Cameras
''New'' Lens will not Focus,how can I fix this problem
Nikon 18-55mm f/3.5-5.6G ED AF-S DX Zoom-Nikkor... Ask Question , Recently Purchased a new Nikon D60 Digital SLR Camera, the Camera is less then 3 weeks old, today I went to use Camera and when I turned on the Camera, and looking through the view finder,everything was blurry. Tried other lens's and all worked fine. The above lens, would not focus. What can I do to correct this problem? Safety 56
    Problem Solver:
  • 18 Answers
Try Nikon's website for connection to their Technical Support. www.nikonusa.com
Posted on Jun 11, 2009
SOURCE:
Autofocus on Nikkor 18-55mm lens doesn't work
probably you have problem with the focus motor, i ever have same problem and need to replaced the focus motor.
Jun 08, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
What is 55-200mm?
That's the focal range of a zoom lens. Unlike a single focal-length lens (or a "prime" lens) a zoom lens lets you adjust the focal range. "55-200mm" specifies the lens's focal range from 55mm at the low end to 200mm at the long end.
You can read a general description of zoom lenses at
http://en.wikipedia.org/wiki/Zoom_lens
Nikon current has two different 55-200mm lenses:
http://www.nikonusa.com/Nikon-Products/Product/Camera-Lenses/
2156/AF-S-DX-Zoom-NIKKOR-55-200mm-f%252F4-5.6G-ED.html
and
If you're asking about the L110, it has a permanently-affixed lens and will not use either of the above lenses.
Aug 11, 2011 | Nikon Coolpix L110 Digital Camera
I have a Nikon D3100 and want to buy a zoom lens 70-300.Please help I am confused is a Nikon AF Zoom-Nikkor 70-300mm f/4-5.6G compatible? And is it automatic focus?
That lens will work with the D3100, except for the autofocusing. In order to autofocus with the D3100, you need AF-S lenses, such as the AF-S VR Zoom-NIKKOR 70-300mm f/4.5-5.6G IF-ED or the
AF-S DX NIKKOR 55-300mm f/4.5-5.6G ED VR.
May 22, 2011 | Nikon Cameras
The lens only focus at 18 mm, when usin the zoom it doesnt focus at all
Ether The optic sensor is bad, Or the AF Motor is bad. Needs to be service by repair shop, Focus has to be check and Readjusted.
Sep 23, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Nikon 18 to 55 lens wont focus
Check to make sure the manual focus/auto focus switch on the lens is set to A. Make sure the lens is completely mounted to the camera and locks securely. If this does not help, or if the lens was dropped, then you should consider buying a new lens. the cost of fixing the old lens may be at least half of the cost of buying a new one.
Nov 12, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
May 24, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
Feb 05, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Lens Problem
sir, replace ur image sensor,
Feb 22, 2008 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Cameras Logo
148 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
