Honeywell 2000 Watt Inverter Generator Engine HW2000i Logo
A
Anonymous Posted on Feb 24, 2014
Need parts for honeywell hw2000i - Honeywell 2000 Watt Inverter Generator Engine HW2000i
2answers
My honeywell Portable Generator Making A Loud Knocking Noise
Everything is repairable. First thing to do is a full strip down of the engine to see what has come loose. There are 280 models!
Google
make model, parts schematic
0060362 - Honeywell Generators
http://www.honeywellgenerators.com > product-info
Protect what matters most with the power of Honeywell Generators. ... Parts Manual / EV (Unit), PARTS MANUAL HW5500 49ST/CSA, 0J9776PMNL, EN.
Honeywell Generator Parts and Parts Diagrams
https://www.m-and-d.com > Honeywell_Generator_Parts
Matches 1 - 50 of 280 - Finding Honeywell Portable Generator Parts is simple with our online parts diagrams: 1. Click on the section of the machine for which ...
Honeywell Generator Parts & Spares
https://www.generatorguru.com > honeywell
Buy Honeywell Generator Parts now. Advice available from the leader in Portable Generator Parts. USA Canada UK EU AUS NZ.
Is there a current recall or fix for an apparent common problem with the Honeywell HW2000i in regards to starting this unit?..I have heard and read about dozens of owners having the same problem..
I noticed one of the reasons the engine can shut off is due to lack of engine oil. Just being curious whether you have filled up oil in the crankcase. The manual says there is a engine protection system that operates if engine oil is not at the right level. Make sure you have used the correct grade of engine oil.
2answers
Start run 2 min cut off then wont fire 30 hrs
check the coil.( dis pack) when they fail or start failing the spark at the plug goes orange should be a nice blue spark.
Need user's manual
crank run 2 min.cut off no fire from coil 24 hour later crank run 2 min
When the load goes up so will the voltage
no it wont, is an inverter unit, voltage is regulated.
Coil is bad in my hw2000i
Go on line to the Honeywell website and check out users manuals. They probably have a download you can get!
What type of oil and how much do I use with the honeywell 1000w generator?
Engine Oil Recommendations
Use 4-stroke oil, or equivalent high detergent, premium
quality motor oil certified to meet or exceed U.S. automobile
manufacturer's requirements for API Performance
Class SF or better. SAE 15W-40 is recommended for general,
all-temperature use.
NOTICE
Engine oil is a major factor affecting engine performance
and service life. Non-detergent and 2-stroke engine oils will
damage engine and are not recommended.
• Be sure to use engine oils specified under "Engine Oil
Recommendations."
It is very important to maintain proper level of engine oil to
keep engine in good running condition.
• Check engine oil level prior to each use. Refill engine
oil if oil level is low.
FIGURE 17: Recommended Oil Viscosity
Crankcase pressure can cause hot engine oil to
spray out of engine fill hole. Hot engine oil can
cause severe burns.
• ALWAYS stop engine before removing the oil fill cap.
15W-40
WARNING
FIGURE 18: Oil Fill Cap Removal
FIGURE 19: Oil Fill Measurement
Oil Capacity [qt / ml]
HW1000i 0.26 / 250
HW2000i 0.48 / 450
TABLE 4. Engine Oil Capacity
Mar 08, 2011 • Garden
Top Honeywell Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you a Honeywell Electrical Supply Expert? Answer questions, earn points and help others
