Hello! If your JVC TV is displaying an onscreen remote and you're unable to use the actual remote, you can try the following steps to resolve the issue:
Power cycle the TV: Turn off the TV and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This can often reset any temporary issues and restore the functionality of the actual remote.
Replace the remote batteries: Check the batteries in your remote control and make sure they have enough power. If the batteries are low, replace them with fresh ones and try using the remote again.
Check the remote control sensor: Ensure that there are no obstructions between the remote control and the TV's remote control sensor. Clean the remote control sensor on the TV with a soft, lint-free cloth to remove any dust or debris that may be interfering with the signal reception.
Reset the TV to factory settings: If the issue persists, you can try resetting the TV to its factory settings. Keep in mind that this will erase any personalized settings and restore the TV to its original configuration. Refer to the user manual or the manufacturer's website for instructions on how to perform a factory reset on your specific JVC TV model.
Contact JVC customer support: If none of the above steps resolve the issue, it's recommended to reach out to JVC customer support for further assistance. They will have access to more specific troubleshooting steps and can guide you through the process of resolving the issue with the onscreen remote.
Keep in mind that the exact steps and options may vary depending on your specific JVC TV model. Refer to the user manual or contact JVC customer support for model-specific guidance.
check your batteries to make sure they are good. if they are good you may need to default the remote and reprogram. if this doesn't fix it you will need another one
If the remote control is not broken, the batteries are almost out of power supply. Especially with remote controls that perform multifunction capabilities like with universal controllers. Replace the remote control with new powered batteries. Important notes include being weary of the capacity battery power supply because some brands are incabable of providing supply to remote controllers. For example, unless the remote control requests specific brand battery power supplies, energiser or duracell bateries would power up any device.
turn off your cable box turn off the dvr disconnect cable box from wall outlet disconnect dvr from wall outlet unplug e-sata cable from dvr replug e-sata cable back in to dvr plug dvr into wall outlet turn on dvr plug in cable box to wall outlet turn on cable box wait for cable box to go completely thru startup procedure ...then try your list button again.
first try replacing the batteries in the remote, second make sure that the remote is adjusted to "tv" using the input button. The "cable/tv " selects the input being either ant or cable. google for owner's manual for more infromation..
I don't know if you have this problem but I had a similar problem aswell. My TV remote and my universal remote wouldn't turn on or perform any of the funtions as they should. This is what I did to fix it:
1. unplug the TV from the power outlet.
2. take the batteries out of your TV remote.
3. press the power button on the TV remote, and then press every other single button one by one from left to right (as if you were reading a book).
4. plug the power cord back in the power outlet.
5. replace the batteries in your TV remote.
6. try turning on the TV using the factory remote.
These steps, as weird as they sound, worked just fine for me. My TV is now responding to my remote and my cable remote is able to control the TV again. No, I did not loose the universal (cable) remote's TV codes. FYI. the steps mentioned above were performed using the TV native remote (factory remote). Hope this will work out for you as well. And if you are wondering how I knew this would work, well I saw the same steps on another website (sorry I can't remember which website it was) and decided to give it a try before I took the TV back to BestBuy for warranty repair...which would have taken like two weeks.
I had the same issue this morning so my apologies for the delay in answering you. After numerous delays and frustrations in being unable to "update" my remote i did the following. First, remove all batteries and disconnect remote from the USB cable. Check ALL buttons to ensure that none are stuck in the down position. I found that my SELECT/OK button was stuck in the "on" position. Continue to check all buttons to make sure all test fine. After doing this hold down the "Off" button while connecting the USB cable, still no batteries in the unit at this time. Hold the "Off" button down for at least 10 seconds or until the units Testing is completed. If the Harmony remote software is up, perform the Update Remote step still sans batteries. After it completes it may perform a self test again (mine did) and after it completes then insert the batteries back into the unit. Hope this helps.
