Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby Belt Lifter Assembly
How does the belt lifter go together on the Kirby vacuum head?  I broke the outside  plastic piece which turns to lift the belt on and off.  I have repaired that piece but am not sure where  the plastic washer and the two metal washers go when putting it back together.  I think the plastic washer goes inside of the  vacuum head with the two tabs facing outward towards the front of the vacuum head but I don't know how the wavy metal washer and the flat metal washer fit together or if they should go inside the vacuum head or outside of the vacuum head.
Thanks for any assistance you can provide.
  • Anonymous Feb 17, 2008
    I just had the same problem with my kirby tradition and can't figure out how to put it back together or if something just broke.
    Please help, its the only vacuum in the house
    Scholar:
  • 146 Answers
I have tried to get a parts breakdown for your vacuum cleaner with no success. The way that then washers should go is the flat smotth metal washer on the inside followed by the fibre washer and the wavy washer on the outside. The waves are used to bite into the plastic so it cannot work loose.
Posted on Nov 09, 2007
Kirby heritage 2 How to put the belt on. I'm having a problem getting the belt on the rod
The belt goes around the brushroll before you install the brushroll in the nozzle compartment, you must then twist the belt lifter casting which will rotate the belt lifter hook to lift the belt into the proper location to allow you to install the nozzle compartment on the vacuum. Then rotate the belt lifter casting to release the belt onto the motor shaft.
Sep 14, 2017 | Kirby Vacuums
Green light does not come on ans brush does not move. belt is good and brush does spin manually.
I assume this is a Kirby. The belt is not on the motor shaft if you can turn the brush manually. Remove the head, turn the belt lifter assembly clockwise to stretch the belt into a loop, place the head back onto the motor unit and latch it in place, then turn the belt lifter counterclockwise to drop the belt onto the motor shaft.
Jan 22, 2011 | Vacuums
My Kirby is not engaging the belt after it was put back on. I took it off to clean brushes and did everything according to the video but the belt will still not engage and green light does not come on.
The belt is not on the motor shaft. Remove the head from the motor unit. With the belt centered on the brushroll, turn the belt lifter a full 3/4 turn counterclockwise to stretch the belt up onto the belt lifter finger. ( Look through the back to be sure the belt is streched into a loop over the finger.) Plce the head back on the motor unit and latch it in place, then turn the belt lifter fully clockwise to drop the belt onto the motor shaft. Be sure the brushroll is correctly installed in the head. Setting # 1 should face the floor.
Dec 19, 2010 | Kirby G5 Bagged Upright Vacuum
How do I change the belt on my Kirby sweeper?
1)First, you turn the square belt lifter on the front of the power nozzle until the red arrows line up (belt off)
2)Remove the power head from the front of the machine. Now turn the belt lifter the other way and line the green arrows up again. This releases the tension on the belt
3)Turn it upside down and release the two clips that hold the metal baseplate on and remove the baseplate and you can access the belt.
You can get a replacement belt here:
Kirby Ultimate G Replacement Belt
Oct 28, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Belt troubles
make sure the belt is on the belt lifter look in hole on back of head once head is locked on power plant turn belt lifter clockwise to put on shaft
Jul 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby g4 belt replacement
Facing vacuum,turn belt lifter knob counterclockwise till it stops.Lift headlight hood,and unlatch brushead,and remove.Looking thru the hole in back,turn belt lifter knob clockwise to release belt.Remove bottom plate,and bend one end of bracket to remove end of brush roll.Slip new belt on and replace brushroll back into bracket,and replace bottom rug plate.Looking thru hole in back,turn belt lifter knob until the hook inside picks up belt.Replace brushead,and again,turn belt lifter knob clockwise to drop belt onto shaft.
Dec 18, 2008 | Vacuums
How do you install the belt on the kirby vacuum?
Step 1:
UNPLUG YOUR KIRBY VACUUM CLEANER. Before you go any further, take your time with this belt change. It's not that difficult, just a little different than most other vacuums. These belts are very easy to find on the internet. kirby-oldstyle1.jpg Step 2:
You should be facing the front of your Kirby vacuum. The height adjustment lever will be on your right. Push the lever all the way down. Lift the light hood with your left hand. Turn theKirby vacuum belt lifter counter-clockwise with your right hand. Unlock the accessory lock. The accessory lock is located under the light hood. Move the lock to the left to disengage it. Remove the front of the vacuum cleaner.
kirby-oldstyle2.jpg kirby-oldstyle2a.jpg Step 3:
Turn the vacuum belt lifter all the way clockwise until the belt drops down. Unlock the roller plate by releasing the two latches on the rear. Pull the roller plate up slightly and then off. kirby-oldstyle3.jpg kirby-oldstyle3a.jpg
Step 4:
Bend one end of the roller bracket just enough to remove the roller. Remove this end of the roller. If you need to replace the roller take it all the way out. Remove any carpet fiber, string, or hair from the roller with a scissor.
kirby-oldstyle4.jpg kirby-oldstyle4a.jpg Step 5:
After you have removed the old belt, slide the new one back on the middle of the roller. If you're Kirby vacuum cleaner has a belt indicator light, the roller will have a magnet built onto one end of it. It's very important to install to install a roller with a magnet on the same side as the indicator light. The roller actually will only fit into the roller plate one way.
kirby-oldstyle4.jpg Step 6:
Place the roller back in the roller bracket. Place the roller bracket back and lock it into place with the 2 latches. Rotate the vacuum cleaner belt lifter counter-clockwise. You should feel the the belt catch. Look inside to make sure the belt is being stretched onto the vacuum belt lifter. Reassemble the machine. After you have reassembled your Kirby, turn the belt lifter cockwise, releasing the vacuum belt onto the vacuum motor shaft. kirby-oldstyle2.jpg
Nov 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
How to remove the plastic belt lift knob?
There is a screw underneath the sticker on the belt lifter. It's in the center of the belt lifter. You'll have to make a small hole in the sticker to get to it.
Aug 18, 2008 | Kirby Ultimate G Bagged Upright Vacuum
How do i put together my kirby carpet shampoo system?
Vacuum thoroughly before shampooing for maximum cleaning. Then, remove the bag and the Power Nozzle to prepare for shampooing. Turn the Carpet Shampoo System Nozzle Belt Lifter to the right of the center position (fully clockwise) until the green arrows line up. a4bbc62.jpg Slide the slots on the side of the Carpet shampoo system over the outer shoulders of the Carpet Shampoo System Tray. e14fe2e.jpg While pushing up on the Belt with your finger, turn the Belt Lifter left (counter- clockwise looking at it from the front) until the red arrows line up. (The Belt Lifter Hook will catch and stretch the belt.)
Press the bottom Toe Touch Pedal all the way down to raise the front of the Kirby.
While sliding the carpet shampoo system Nozzle/Tray Assembly toward the Kirby and over the Motor shaft, connect the hooks on the bottom rear of the nozzle to the Attaching Bar.
Push the nozzle up against the Kirby and turn the Accessory Lock to the
right (clockwise) to lock the nozzle in place. To engage the belt, turn the Belt Lifter
all the way to the right (clockwise) until the green arrows line up. Then lower the Headlight Hood
Apr 18, 2008 | Vacuums
Re-connecting Vacuum Head
on the kirby head is a square knob with the kirby name on it. use your finger and pull out the belt and rotate the knob until the metal pawl engages the belt. keep turning until it stops. the belt should be in the correct position to install the head. place the whole head onto the lower two tangs and lift up. now rotate the wedge clamp until it stops. then rotate the belt lifter till the knob is straight.
Aug 28, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
392 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
