Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Purple lines moving diagonally on screen
I had this hdtv for almost 2 years and now it starting to have these lines moving on the screen. I thought it was the cable tv but I unplugged all the component cables and its still there.
The HDMI port works fine. All the component connections has this problem.
Anyone might have a clue what is going on?
This happened to me last year with the same set. Had it repaired - they replaced the "PCB Formatter" board and the problem was solved. But unfortunately, less than a year later, the problem has coem back. Good luck!
Posted on Oct 29, 2007
New RCA TV just out of the box, show's nothing but green diagonal lines.
Recommend contacting the seller and tell them you are bringing it back and why.
Mar 05, 2015 | RCA L42FHD37 42 in. LCD HDTV
How do I get rid of diagonal lines across my Mag. HDTV screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 06, 2014 | Magnavox 19MD359B F7 19 in. HDTV
Sony KDL-50EX645 purple vertical line between the panel
In most of the case, the display panel (screen) is bad. Please contact SONY customer service ASAP.
Apr 17, 2014 | Sony KDL-50EX645 50" LED TV 1920x1080, 240...
I have lines going through my TV. It hasn't been moved not hit and when cleaning it I used a computer screen cleaner with the tool it came with. It is over a year. Now what?
are they vertical or horizontal ? in a samsung if the screen is not broke or cracked the problem is the screen video processing board
Sep 29, 2009 | Sylvania 32 in. Diagonal LCD HDTV
Purple and green rolling lines after lightning storm
I have exact same problem...other posts have cited improper grounding from the Cable...which makes sense as the problem does not occrr with the DVD...I have not figured out how to fix it though...
Aug 12, 2009 | Panasonic TH-50PX75U Plasma HDTV
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Diagonal lines on upper 1/3 of screen
It sounds like the dmd board may be defective but you can try rebooting the set and see if it makes the picture any better...
1 - Turn on the Tv.
2 - Press & Hold the up arrow key on the remote and then press the power button on the front of the Tv.
3 - Tv will reset & reboot
If the picture is the same it's probably the dmd board which is part of the "B" block assembly and I don't believe they're sold separately. The "B" block is about $1100.00 dollars.
Hope this helps!
Bill
Apr 23, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
194 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
