Question about Canon PowerShot G6 Digital Camera
Does not Turn on!
All of a sudden, my G6 won't turn on.  I have 2 battery packs, both have been recharged, neither work.  I cleaned the contacts on them.  Don't have a clue what else to try to avoid paying $150 to Canon for repair service.
Thanks!
  • dick40 Jan 29, 2008
    G6 will not turn on using a battery. Works fine with AC adapter. Batteries seem to be fully charged. Even a new, charged battery does not work. Tried replacing the Compact Flash Card with the original (supplied with camera). Did not help.
  • 421 Answers
We returned the the G6 (Jan 29, 2008 post) to Canon for repair, cost $139 plus $8 shipping (not including shipping to send it to them). Learned nothing about what caused the problem. The camera now works with its old CFcard, old battery, etc.. Definitely a camera problem, with a camera only slightly used, and only a few months out of warranty! Not very happy.
Posted on Feb 11, 2008
Hi, Ibought a new G6 a couple of years ago and lo and behold after formatting a new CF card I had this problem. Was I frustrated ! ! A new camera that was malfunctioning. going straight to the matter it was found that my new CFcard was faulty ! Maybe it could be the same problem as mine! hope this may help you. JK
Posted on Nov 08, 2007
My Olympus VG120 won't turn on. fast indicator lamp
1) change the batteries by new ones or recharge well the batteries
2) must be shure to use the o.k batteries type
3) clean the contacts batteries with contacts cleaner
4) poor contact between the cover camer and batteries contacts adjust it, and clean it
5) Wrong polarities with batteries inside.
6) memor card/slot/battery cover open
Jul 31, 2012 | Olympus Vg-120 14mp Digital Camera Silver...
I have a pair of walkie talkies, rechargable, but one of them wont work with the battery pack. Both battery packs work in the other one, but this one will only work with 5 AAA batteries. Any ideas out
If your rechargeable battery pack takes a different battery tray than the alkaline, you possibly have a bad connection in the battery tray. If they appear to use the same battery contacts, look at where the rechargeable battery touches compared to the alkaline. There may be a problem in this area. Clean all contacts with a pencil eraser to insure your radio is free of debris on the contacts.
Best regards.
Feb 24, 2012 | Columbia Telecommunications Group Radio...
My xbox 360 wireless controller won't turn on
If it has a rechargeable pack on it try swapping it out with a "AA" battery pack. sometimes the rechargeable batteries can go bad. If the controller still won't turn on then you have an internal problem and you will need a new controller. :)
Or you can try getting your controller fixed, although there in not very many people that are willing to work on controllers
Nov 14, 2011 | Microsoft Xbox 360 Console
My camera won't turn on i charged it and now it won't turn on!
This truly depends on the make and model of your camera. If it uses a rechargeable pack, make sure to fully charge the battery and try it. If this still doesn't work, try plugging it in the computer via USB. If it turns on, then your battery pack may be causing the problem. I would suggest you to bring it to your nearest service center for them to check it out, especially if you still have warranty and so they can replace the battery pack. Some cameras have a reset button at the very bottom (or look into your camera's manual if there is such a thing for your camera) which could be an option as well.
Jun 14, 2011 | Cameras
I bought grundig G6 at Boeing Store,when i turned the radio ON it suddenly turned OFF by itself . i always tried to press ON until 5 times n suddenly it works normally, n if i press the AM,search UP,or...
That unit is not made any longer. There could be an issue with the buttons. They are most likely carbon pad. They can degrade over time and no longer work correctly. In some cases you can take the front panel off and remove the membrane with the buttons and clean them with alcohol and clean the pad they contact and reassemble. However this could also be a bad capacitor that holds the charge when the button is pressed.
Nov 27, 2017 | Grundig G6 Aviator Radio Buzz Aldrin...
My camra worked just fine, then when I tried to turn it on it wont turn on no matter what I do
Please try the following: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 23, 2010 | Kodak EASYSHARE Z1285 Digital Camera
I'm going through batteries like crazy. Is there a recharger anyone can recommend for the EASYSHARE Z1485 (crv3 3v)
Here are the steps:
NB: You are using the correct battery pack.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 20, 2009 | Kodak EASYSHARE Z1485 IS Digital Camera
Camera suddenly stopped working--an error message flashed, then camera shut off-put new battery in--nothing happens. (kodak c360)
Usually when the camera shows an error mgs. it needs a repair
However Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
3. Without the memory card,turn on your camera.
Contact KODAK:
Nov 23, 2009 | Kodak EasyShare C360 Digital Camera
A640 freeezes while taking pictures
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Sep 27, 2009 | Canon PowerShot A640 Digital Camera
My kodak digital camera won't turn on.
First, remove the SD card (if there is one) and see if it works. If it does, then the SD card is damaged. If it still doesnt work, read on..
Try regular alkaline batteries. If they work, it could indicate that your rechargeable batteries are dead and need to be replaced, or there is a problem with the charger.
If the regular batteries dont work either, try cleaning the contacts in the battery compartment of your camera, or gently scratching the contacts with a jeweller's screwdriver. If it still does not work, there is an issue with the camera's power board and it will require servicing.
Nov 26, 2008 | Cameras
Canon PowerShot G6 Digital Camera Logo
473 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
