Question about Nintendo Super NES Console
Snes wont work
I have a snes.all the wires are in working order and the television is tuned in correctly but when i insert a game in and press power on there is a black screen.the games wont work.
  • Anonymous Nov 13, 2007
    I have the exact same problem. Just a black screen and no display. When I first power on the system the screen will briefly turn a dark red color but then goes to all black. This is all in excellent condition and everything is connected properly, game is clean, etc. Reset does nothing either.
  • Anonymous Apr 10, 2008
    Very similar problem. I'm trying to attached to a new(ish) LCD TV. When the SNES is switched on most of the channels just have snowflakes, one or two channels display a black screen but return to snow when the SNES is switched off. Just as a thought are the games liable to "die" if not used for several years ? The TV must be getting something to display a black screen when the SNES is on.
    Any suggestions gratefully received.
    Guest
    Problem Solver:
  • 12 Answers
How did you clean the game? Certain "surefire" ways may actually damage the game.
Posted on Dec 10, 2007
    President:
  • 894 Answers
Well to clean out the gamepacks use qutips and rubbing alcohal then. Or there might be a loose or broken connection with the console somwwhere inside of it.
Posted on Jun 16, 2011
Strange missing pixels/ discoloration for SNES
Hi the prob is the snes system itself its getting worn out
Apr 08, 2012 | Nintendo Super NES Console
Hi i just got a fc twin and i am trying to get a nes mario/ duckhunt game to go in and i cant figure it out.. i have other games but they wont go in eaither
The front slot is made for NES games such as mario/duckhunt, and the back slot is made for SNES games. Make sure you put them in the right direction as well.
Good Luck,
Rodrick
Apr 22, 2011 | Vs Clothing FC Twin Video Game System for...
When i plug my snes to my tv it wont work :/ i plug the cable to tv and put the snes on chan3 then i go on channel 3 with my tv and it show me a black screen ,sometime i hear 2 sec of the game music :/
Hi pikapike,
I see you are going back to the 90's with your Super Nintendo. Firstly I do not know how you can "put the snes on chan 3". If I am correct, all super nintendo cables to the TV are RV coloured ones. therefore once it is plugged into the TV, you will ant the A/V channel? which usually has a separate button.
Secondly if what you say that you get a flash/glimpse of the game, then check the system of your TV. Is it PAL (Europe, Aus, NZ, etc) or NTSC (U.S.) Hopefully you can change the TV settings to match your game console!
Hope this helps,
kamacosmic
Feb 19, 2011 | Video Game Consoles & Games
Super NES Console: My super Nintendo gets power (red light turns on) ...
Maybe the one that is not turning on to play game is broken then. Ensure that you have a known-good game cartridge inserted before powering on the SNES console. Most older, cartridge-based game consoles don't boot without a game installed.
Does the power light to the left of the controller ports turn on when you turn on the power switch?
If not, check your power adapter and outlet for functionality and good connection.
Check that the reset switch is not stuck. Wiggle it back and forth through its range of motion a few times. If something sticky gets in there it can get jammed in the reset position, which will prevent any game from booting.
You mentioned that there is no image. Are you getting any sound from your games after waiting a few minutes with everything connected and turned on?
If you hear game sounds or music from the SNES, but see no picture and you've already (really and truly) ruled out the cabling and TV, then you might have a bad main board in the console.
If you don't get any video or sound, then it's not booting your game. You can find other recommendations about how to clean game and console connections, but usually inserting and ejecting a game 10-20 times will knock loose or grind off enough gunk to get a game to boot. Try this, and be sure to use the eject lever instead of ripping the game out to avoid console connector damage. If it's still not working, repeat with another game.
May 18, 2010 | Nintendo Super NES Console
Hi i just bought a super nes system it came with RF switch power unit which i have connected to the appropriate connections, i have an LG TV with an golden eye and don't seem to be able to tune the...
Make sure everything's connected in the correct sockets. Turn the SNES on, change to one of the Analogue channels (one of the channels which you control with the TV remote) and start scanning for a signal. The RF cable has to be connected to the analogue port (where a TV aerial would plug in to get analogue channels) and the SNES needs to be switched on.
The alternative is to get a SCART-compatible cable that works with a Gamecube or an N64 and use it with the SNES, as Nintendo had the foresight to add an EXT port which'll let you play the SNES on an AV channel.
Jul 09, 2009 | Nintendo Super NES Console
Yobo Nes FC Console
No the yobo fc is eight bit annthe super nintendo is 16. Also it wont work the other way around either, so don't buy any FAKE adapters!
Feb 19, 2009 | YOBO FC Game Console
SNES problem
Make sure you are using only licensed accessories with your system.
We find that video problems occur most when an unlicensed RF switch is used. Make sure the name "Nintendo" is molded onto the RF switch, as opposed to "for use with Nintendo." Unlicensed products are not fully compatible with our systems and may not work correctly.
Check all of the system connections to verify that they are firm and correct.
For AV connections
Remove the AV cables and reinsert them with a slight twisting motion
For RF connections
Make sure the channel switch on the TV and system are set to the same channel (either CH3 or CH4)
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to make sure it is locked in place.
Important Note: Removing the Game Pak with the power ON will cause the Game Pak image to freeze on the screen. Press Reset to correct the problem. Always turn your system OFF before inserting or removing Game Paks.
Slide the Power Switch on the Control Deck to the ON position.
If the above troubleshooting doesn't fix the problem, see below.
What to do if Troubleshooting Doesn't Help
Aug 23, 2008 | Nintendo Super NES Console
Denon 3808ci won't upconvert old video game consoles
Since the games are so old and the SNES is an ancient console most tv's are made for the newer ones/Wii, Xbox, ETc./ So The Tv May Require Certain Wires for the console to function correctly, it also may be that your wires for the SNES are corroding in side *( Copper Wires Etc. )
Dec 12, 2007 | Denon AVR 3808Ci Receiver
My snes won't read games
have u try cleaning the connectors on the game with alcohol
Oct 28, 2007 | Nintendo Super NES Console
Nintendo Super NES Console Logo
292 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
