Everything works great, except the water never goes into the fabric softner. I have to manually put the softner in when the water goes into the other side. Stupid, but I am not paying the $400 for the new control thingy!
I have the maytag neptune stackable washer, dryer, it does not spin, I have had 3 people look at it....
(More)
I have the maytag neptune stackable washer, dryer, it does not spin, I have had 3 people look at it. None can figure it out. Please Help. The wash runs up to the spin cycle then just stops.
Maytag model MAH3000 won't shut off after final rinse. Trouble shooting document in washer control...
(More)
Maytag model MAH3000 won't shut off after final rinse. Trouble shooting document in washer control panel says ''End of cycle signal ON/OFF'' Machine control connector/wire = P5 (WH11) & P2 / 1 (PU21) 24VDc ON O Vdc OFF; Timer Contract = Not Involved. Does this mean the board is bad because the Timer is not involved?
The unit keeps filling until water leaks from the door. Unless we hit the stop button the machine...
(More)
The unit keeps filling until water leaks from the door. Unless we hit the stop button the machine seems to be willing to keep filling, even while it is in 'drain' mode.
We have a Maytag front loading washer purchased in 2005. We have a problem with black flakes about...
(More)
We have a Maytag front loading washer purchased in 2005. We have a problem with black flakes about 1/16 to 1/8", coming out with the clothes when removed from washer. We shake the clothes and have to vacuum floor after each load. We use he detergent as recommended. What can we do?
Is it normal for a "Quick" cycle on the Maytag Neptune to take 53 minutes? "Normal...
(More)
Is it normal for a "Quick" cycle on the Maytag Neptune to take 53 minutes? "Normal Soil" is 78 minutes? My old machine did a great job in 25 minutes.
