Question about Sony PlayStation 2 (PS2) Console
Online gaming i have a terayon tj715x cable modem, d-link wbr2310 wireless router and a linksys rtp300 broadband router for voip. besides a network adaptor, what else do i need to have for ps2 online gaming? thx,
    Problem Solver:
  • 22 Answers
Did u make an internet connection on that counsel?...using the provided disc that u got wen u purchased it...also...remove 1 of ur routers...u only need 1, and both gaming councels and PCs don't like twin routers. u do need a memory card too...=3, im sure u knew that tho...lol
Posted on Feb 05, 2008
Need driver and firmware for LinkSys RTP 300, or how to set it up for simple home network with interneton the PC and laptop as the 2nd computer.
No drivers are required since there is no actual installation to to the computer. Connect the ISP modem to to the main LAN network port. Then use any available port to access network. 1.Power 2.Main drop. 3.Network. That's it!
If the router is used, you may want to reset custom settings by, holding in the reset pin till it cycles.
Advance setup.
http://www.cisco.com/en/US/docs/routers/csbr/rtp300/installation/guide/RTP300_UG.pdf
Oct 16, 2012 | Linksys Rtp 300 Broadband Ethernet Voip...
No connection
Are you trying to set up router ?
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Jun 26, 2010 | Linksys Wireless-G Broadband Router
My Linksys wireless router doesn't seem to be accepting signal from my cable modem and thus not transmitting or transmits very slowly. Modem works fin alone. How do I reset it to work again?
Mar 11, 2010 | Linksys Wireless-G Broadband Router
Have linksys broadband router model # rtp300, formally used to receive Vonage service. Can this devise be used to connect a second computer in my home?
Yes.
This is a wired router.
you can connect second computer to the router.
You will need to connect the cable to the router's ethernet port and computer.
Click Here to know more about router and network
Feb 04, 2010 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Vonage router settings
Are you able to go online when you connect the computer directly to the modem ( without the router ) ? If you are online with the modem, then you can set up the router manually.
Click Here for step by step solutions
Nov 03, 2009 | Linksys IP TELEPHONY - VOIP RTR W/ 2 PHONE...
I have broadband cable service. My cable modem ic connected to a Linksys Dual band wireless router. My computer is then connected to the wireless router on USB port 2. My Link sys VOIP is connected to the...
First unplug your router, then unplug your modem and for 10 seconds. Next plug the modem back in and wait it to reboot(on mine this a series of 4 lights that light up in sequence, when the 4th light stops flashing, reboot is complete). Finally plug your router back in.
Sep 09, 2009 | Linksys Ultra RangePlus Dual-Band...
Need software for linksys wrt54g wireless g broadband router
  • goto linksys.com and search for the modem number of the router, and search for the frimware
Aug 11, 2009 | Linksys Wireless-G Broadband Router
Linksys RTP300 Broadband VOIP router W/2 phone ports
Have you tried to do a hard reset on the unit?
Apr 05, 2009 | Computers & Internet
Want to know how to connect another pc
Your specific model router RTP300-NA, doesn't have wireless capability- you'll need to run a cat5 or cat 6 cable to connect your pc. You may be able to share the connection from the primary pc using two wireless adapters, but it would be easier and cheaper to get a different router with wireless.
Hope that helps!
Jan 04, 2009 | Linksys IP TELEPHONY - VOIP RTR W/ 2 PHONE...
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Sony PlayStation 2 (PS2) Console Logo
64 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
