This fix will work for all of the VEO Stingray problems because it
gives a good driver download site and it tells you step by step how to
get your cam to work with VISTA Good Luck and let me know if this fixed
your problems.
1.Go to this site and download the driver you need: http://www.softsci.com/veodrivers.htm
2.Download it to your desktop
3. Don't unzip, install, or plug in your cam yet
4.Search for this in your start menu: Program Compatibility Wizard
5. Of the three choices click the one that says look for the program manually
6. Choose the option for XP
7. Choose the 680 x 420 or whatever it is not the 256 colors
8. Choose to run as administrator
9. Click next and it should change your screen to a real big resolution and then it will start to install the driver
10. Go through the install wizard
11. After it has loaded plug in your camera
12. Try a program that it is supposed to work with
13. Finish the Compatibility Wizard
now everything should work for your cam. This works with all of your programs that vista will not run.
I am trying to get my Veo Stingray Web cam to work with Windows Vista but I need to find the...
(More)
I am trying to get my Veo Stingray Web cam to work with Windows Vista but I need to find the software and driver compatible with Windows Vista. I had been using it with windows xp. home edition.
my cd comes up with errors so where on line can i download all the files i need for veo stingray...
(More)
my cd comes up with errors so where on line can i download all the files i need for veo stingray v001
