Hello, my name is Israel. I will be glad to help you. You will first need to push and hold the selct button. DEMO will show on the screen use the |<< and >>>| buttons to select clock. Use the voulume knob to adjust the hour and then select the minutes and adjust as you did the hour. When finished push the select button.
Press and hold SEL until menu appears Using the scan button (FWD/REV), select Clock H Using the volume knob, set the value Using the scan button (FWD/REV), select Clock M Using the volume knob, set the value Press SEL to save and exit
its simple. hold the "sel" button until the menu comes up and it will say hours use the volume button to change it. then use the next button to go to the minutes. then you can also change other settings under this menu. hit the "sel" button again to go back.
how to pre set radio stations
