Question about Frigidaire Kitchen Ranges
Frigidaire Stove Model # FW557W-3... clock will not light up, where is the fuse? Where can I get an owner's manual?
5 Suggested Answers
SOURCE: frigidaire electric stove model fef369cgsb
Apparently an electrical problem - possibly in the unit, but possibly a breaker. In my case, once we extended the cord a bit, the problem solved itself. Can also be a loose connection in the receptacle, or fraying in the cord, but in my situation just rearranging the power cord did the trick.
Posted on Aug 05, 2008
SOURCE: Tappan Series 110 Gas Stove Owners Manual
stovetop works well, oven will not ignite. Whats up?
Posted on Oct 03, 2008
SOURCE: Frigidaire Stove clock resets to 12:00 when igniters turned on
I have the same problem. This is an intermittent problem, maybe once every 20 to 30 starts the clock goes resets and the appliance beeps just like if unplugged it and then plugged it in again. I’m an electrical engineer and this sounds like the microcontroller that runs the appliance is being reset by noise caused by the spark igniters. This is definitely a design problem. Separating the wiring of the igniters and the control board should help. When I get a chance I’ll have to connected an oscilloscope and look at the noise. The control board microcontroller reset pin probably needs an RC snubber or an isolated ground. If /when I find something more definite, I’ll place another posting.
Posted on Jan 18, 2010
SOURCE: frigidaire deluxe electric stove Model# RDG3-35S
The pipe is a vent pipe it is normal and th fuse is behind the back panel right behind the pots and pan shelf beside the stove pull the shelf out and replace the fuse with a 15 amp
Posted on Oct 05, 2011
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
What's wrong and how do I fix it?
The circuit breaker outside in the power panel for the stove has a bad breaker. It will be two breakers with their handles joined together by a pin so if one tripe it takes the other so 220 V is no longer present. When one, but not the other trips you only have 110 V. That's why the lights and clock still work but no heating elements.
Nov 16, 2015 | Frigidaire Kitchen Ranges
I have a frigidaire electric stove,model # 316433603 there is power to the stove the only working is the clock
General answer for all electric stoves: Electric stoves are usually 220V in the USA. The clock is 120V. My first "guess" is that you have 120v to your clock and maybe light if the stove has one. You should have a separate 220v power cable ( see photo attached) that will power the range itself. The cord may be missing ( simple to unbolt), the cord my be unplugged, or the 220 circuit may be turned off at the fuse box or circuit breaker.
Mar 02, 2015 | Stoves Ovens
No power
Your stove should be on its own breaker or have its own fuse. Some models of stoves have fuses within their own control panels too. Check your home's panel to see if a breaker has been flipped or a fuse blown, and follow up with the owners manual for your make and model of stove.
Mar 05, 2014 | Magic Chef Microwave Ovens
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire deluxe electric stove Model# RDG3-35S
Jan 01, 2008 | Kitchen Ranges
Kitchen Ranges Logo
202 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
