Just wanted too know
SOURCE: i have 2 kicker l7 12 dual voice coil subs.. i
it all depends on the impendance of your subs if u have duel 4ohm or duel 2ohm, 2 duel 4ohm speakers can be wired at 1ohm to the amp, and with a kx1200.1 that would be pushin 2400 peak and 1200rms
if ya have 2 duel 2ohm speaker than you can only wire them to 2ohm and would be pushing 1200 peak and 600 rms with the kx1200, so if you have the duel 4ohm i would go with the kx1200.1 and if u have the duel 2ohm i would go with the hifoncs
SOURCE: amp is pulsating the subs uncontrolably
Hey make sure your ground is good. i had a problem like this befor and it was when i hooked the rca's in it would be pumping out bassing staticy noise and i had no acual ground hooked up took the screw and moved it to scratch the paint and Boom the real Bass came in. ....i thought it was grounded but it was not.
SOURCE: how many watts are in the kicker comp zr600 amp? i
heres a link to a stats page for the zr600>
http://www4.shopping.com/xPO-Kicker-ZR600#keyFeaturesArea
SOURCE: MY KICKER ZX 750.1channel amp "FLIP FLOPS" from
Are you getting any sound output at all from amplifier?
Is there a popping or banging coming from speaker?
It could possibly be a faulty output mosfet that is ocillating cause DC to leak onto the speaker output causing it to flip into protect.
please advise
thanks,ben
SOURCE: ZX 1000.1 amp stays in protection mode
It is normal for them to go into the protect mode, If the speakers are not hooked up to it,
