Question about Sony KP-41T65 41" Rear Projection Television
Sony kp-41s3u 50" hissing sound
Just recently my tv has started to hiss when it is turned on. the picture and sound are fine but i noticed a blue glow around where the hissing is coming from at the back. what could this be and is it worth fixing???
    Sergeant:
    Champion:
  • 375 Answers
Sounds like high voltage arcing,caution
Posted on Oct 28, 2007
My tv has a loud hissing sound from the rear.Sounds like an air leak.The stand by light flashes 5 times and the picture is all messed up.What can I check?
A suggestion here: Carefully remove back cover and plug set back in and turn on---DO NOT STICK YOUR HANDS INSIDE!---Try to locate where the sound is coming from---the 5 blinks is an error code--If model is correct as listed here I or you can GOOGLE the model number with "5 blinks" to see what that code means--clearly related to the hiss you hear.
My money would be a high voltage issue but correct model number needs to be confirmed.
Apr 02, 2012 | Sony KP-61HS10 61" Rear Projection...
Kp 61HS30 TV Had the tv since 2002. been a great tv. Just recently it started making a noise when you turn it on. Noise fades away after about 10 seconds. Noise kind of sounds like a dvd player trying...
If you locate the audio board, check for dried up electrolytic capacitors and dry joints around the output IC itself.
That should fix your fault.
Nov 27, 2010 | Sony KP-61HS30 TV
Hissing sound from speakers and the picture turns off.
That model set was known for Chinese capacitors that failed, replace the power supply or look for bulged caps and replace them if your able to
Jan 06, 2018 | Philips 32MF231D Television
Sony Videoscope TV continuous hissing sound from back of tv and picture seems to be getting worse model kp 46c36 year 1997 once tv has warmed up hissing sound stop but picture still a little iffy
Ur high voltage is dying,the FBT,the flyback transformer is the prob.the big block of plastic with a red wire a with a cap hook to the CRT(crt tv).
Sep 29, 2009 | Televison & Video
Hissing sound coming from speakers
I found out that if I manually turn the speakers down on the tv and then turn it up with the remote control the hissing sound goes away
Mar 18, 2009 | Toshiba 65HDX82 65" Rear Projection...
Hissing sound from a Panasonic old TV...Sound and picture are OK. The hissing sound even continues when the MUTE on the Box is ON. The hissing only stops when the MUTE on the TV is ON. I am using the...
If you disconnect or power off the converter box does the hiss go away?
If you connect a VCR or DVD player does it still have the hiss? We
need to isolate what source is causing the hiss if it is from the set or
if it is from the converter box.
When you turn the volume control down on the set, does the hiss
reduce in level? If mute stops it, it should reduce in level as you
turn the volume down. Then turn up the sound level control on
the converter box whether its a manual control or by remote. If you
can get a combination that minimizes the hiss and gets higher sound
level from the programming that may cure it.
I am not familiar with the converter box you are using. Are you using
Audio/Video cables from it to the set or is it coming out with coaxial cable
and used on a channel? If you are using a very old set with a tuner input
perhaps the fine tuning is out of adjustment.
Feb 21, 2009 | Panasonic CT-20D11 20" TV
Loud hissing through rear (souround sound) speakers
I have the Sony Bravia KDL-46S4100. The high-picthed hiss drives me insane. I have a work around but not a fix. Go into your TV's menu and find BACKLIGHT. Adjust it from 1-9 with the house quiet and find what frequency of the hiss is the least annoying.
Sony Bravia high pitch hiss hissing sound high frequency
Nov 22, 2008 | Audio Players & Recorders
LAMP
Replace the lamp. In rare cases, the lamp power supply or lamp ballast may also need replacing. But, replace the lamp first, and use an original Sony lamp not a cheap aftermarket replacement. If this helps, please be sure to rate the fix! Thanks!
Oct 21, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
KP-41S3U
I have a sony kp-41T65 burnt capacitor C514. need specs. Help please. Thanks
Jul 13, 2007 | Sony KP-41T65 41" Rear Projection...
Hissing Sound
A hissing sound that comes from the back of the set (not from the speaker) usually indicates a high voltage leak, most likely around the "suction cup" at the top of the picture tube or around the flyback transformer. Remove the back of the set and turn it on, and when you hear the hissing sound, shut off all the lights in the room and you should be able to see a purple-ish or white-ish glow from the spot that is hissing. Shut the set off, discharge the high voltage and clean and seal the problem area. Of course this should be done by someone experienced with stopping high voltage leaks.
Jun 22, 2007 | Durabrand DU1901 TV
Sony KP-41T65 41" Rear Projection Television Logo
177 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
