Question about Bissell 37603 Upright Vacuum
Bissell 37603 Upright Vacuum smoking
My Bissell 37603 Upright Vacuum started smoking the other day while my wife was using it. I took the cannister off and noticed that the electrical plug between the detachable cannister and the power broom. The vaccum is only 2 years old, and although it is out of the express warranty, I am of the opinon this is due to manufactures defect and is also a health and safery issue. Anyone else have this problem. Please let me know. I haven't been able to reach a bissell rep about this yet but I am hopefule theyc can help.
  • Anonymous May 04, 2009
    My model number is 3576-6 and its smoking. It also seems to never have the suction it originally did. I bought it because of the hepa filter and it was considered a 'good' vacuum if you have pets. I'm not sure I would agreet with that. Anyhow, I'm gonna call bissell and hope for the best.
    President:
  • 1,673 Answers
You need to call Bissell, have your model and serial number handy. They may refer you to as warranty service shop to take it to, but it will be replaced with a new one, and under warranty. Call customer service at (1-800) 237-7691
Posted on Feb 14, 2008
SOURCE:
I replaced the belt and the roller brush moves freely when turned by hand, but when i turn it on, it doesnt. and yes, i release the handle and still no movement
Contact the Consumer Care Associate at 1-800-237-7691. It sounds like there is something more wrong than just a belt replacement. A person to person with Consumer Care may help.
Mar 20, 2015 | Bissell 37603 Lift-Off Revolution Deluxe...
I have a steam cleaner thats old and I don't know how to work it.
http://www.bissell.com/searchresults.aspx?searchType=find+a+user+guide&searchtext=Flip-It&mode=userguides
Sep 21, 2010 | Bissell 37603 Upright Vacuum
Bissell won't start
no reset (self resetting motor) Pull the plu,g leave it off for a day, plug it in a try it again tomorrow. If it doesn't work, the motor is gone
You also need to make sur ethat you get the vacuum back together correctly, some vacums put a swithc in there so that you can't hurt yourself while performing this repair
Feb 01, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
Probably a hose clog. Check the hose on the back of the cannister. Most likely clogged where it attaches to allow debris into the cannister. If cannister is not filling up, that's a sure sign. To remove from top of back of cannister, just turn the ring on the end of the hose to release. Take it outside and push a long thin object through it to force out the clogged hair or debris. The motor is designed to shut off the vacuum cleaner for 30 minutes when this happens to avoid burning up your motor.
Jan 04, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Bissell Lift-Off Turbo power outage
We experienced the same thing. There are several filters on the vacuum cleaner that need to be cleaned out regularly (monthly in the user's guide). But the reason ours was shutting down is a protective circuit that cuts power for 30 minutes to avoid burning up a motor when there is a clog. Our clog was in the hose on the back of the cannister. One end of it can be lifted out of the bottom. The other end locks into place on the top (by rotating the ring on the end of it). It is the path for the hair and debris to the bagless cannister. We found that the top end of that hose was clogged with hair preventing anything from going into the cannister. So if your cannister is not filling, that's probably your problem. Easy to remove the hose and it's only about 18" long, so find something to stick through it and force out all the clogged debris and hair. Good luck!
Nov 13, 2007 | Bissell Lift-Off(R) Revolution(R) Turbo...
No suction
Is there a blockage in the small hose in the bottom of the machine
take of the pod and you will see the small hose,
Is the main hose pushed into the bottom housing
Nov 06, 2007 | Bissell 37603 Upright Vacuum
Bissell 37602 roller stopped spinning
If the roller brush as stopped spinneng .and the brush motor still works the brush belt as broken,
you must replace the brush belt, t
Sep 05, 2007 | Bissell 37603 Upright Vacuum
Bissell 37603 Upright Vacuum Logo
1,031 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
