posted by Shirley Jean on Oct 28, 2007
I have a 2004 Kenmore grill and I only get a small flame on the three burners even when it is turned up to high.
I have plenty of fuel in the tank and I made sure the tank was turned on. Sears put the grill together and it never had a high flame. Now I can't even grill a hamburger. :(
Please help me. It is a $90 fee just to come to the house.
Thank you,
shirlchastain@yahoo.com
Best Solution
posted on Nov 06, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
From: http://bbq.about.com/cs/replacementparts/a/aa071100a_3.htm
Symptoms and Solutions Low Flame: The grill just doesn't want to heat up. This can be cause by several things. Taking it from the fuel source to the flame, lets start with the burner. Newer propane tanks contain a self regulating feature that will automatically slow down the flow of fuel if it thinks it's too high. This can be solved by turning the tank valve off completely and disconnecting it. Open the control valves (on the grill control panel) and ten close them. Reconnect the fuel tank and slowly turn on the valve. Now light the grill to see if that fixes it. Otherwise check the control valve(s) and venturi tubes for obstruction and alignment. Make sure that the flow of fuel is continuous. Check the burner for clogged gas holes. You can usually see this problem by observing how the grill burns. If there are spots without flame then you probably have a clogged burner.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Patio Classic Barbecue Bucket Grill
Email this problem
Email this problem
Can you Help with these Grills and Smokers problems?
Grills and Smokers
Jenn Air lp grill won't light...
I replaced the ignitor and it's... Answer This...
Repair Service
Find Grill and Smoker Repairman Near You:
