Replacement temperature sensor
I have a 2004  BMW Model 330 ci. I slightly damaged the lowest part of the left front bumper. As a  result I have lost the air temperature sensor which is mounted in that location..I have also damaged the connector  to the sensor.I believe the sensor  part number is WO133-1618918. I do not know part number for connector and how these are to be mounted..
  • 290 Answers
To the best of my memory, the connector is part of the front chassis wiring harness. Believe me, you don't want to change the whole harness. I would suggest you call a few salvage yards that may possibly have a wreck they could cut the connector from the harness off of. The connectors are usually mounted by small plastic clips that insert into a hole in the bumper mount. You may be lucky enough to find the sensor, mount and piece of the harness off one car.
Hope this helps.
Thanks/Mike
Posted on Oct 29, 2007
How to reset a soft top for a BMW E46 330 ci
check the fluid level in the pump
Mar 15, 2015 | BMW Cars & Trucks
Bmw 550i 2006 PDC blinking sensor on i-drive
did they du a data stream using a factory scanner-it displays numbrs how each components workin--private shops du this--dont go tu a dealer again they dont keep these machines updated for older cars plus help is unknowledgable-buyin aftermarket electrics is usually troubl-specially w beemers
Mar 24, 2014 | 2006 BMW 550i Sedan
Temperature display isn't accurate
Hi Dale. Look under the front bumper either on the left or right trim panel. The trim panels are triangle in shape. An outside temp sensor usually sits in this area. The sensor may be missing. BMW has the sensor, wire, and connector available sperately if they are missing or damaged. It will cause the outside reading to be -40 and can cause the a/c compressor not to operate.
Feb 29, 2012 | 2000 BMW 3 Series
I need guidance on how to put hydraulic fluid in my 2001 330 ci bmw
This, unfortunately, is one of those "if you have to ask, you should not do it" questions.
There is hydraulic fluid in the automatic transmission and in the power steering pump. I presume that you are interested in the transmission. The synthetic transmission fluid in this transmission is extremely expensive.
You add fluid to the transmission through the hole in the side of the transmission while the car is perfectly level and the transmission is at the correct operating temperature. You determine the transmission temperature using the temperature sensor inside the transmission, and if you had the equipment to do that, you would not have needed to ask this question.
If you know about how much fluid you lost, and you just want to add a fixed amount to replace it, I suppose you can try lifting the driver side up until the car is at a pretty good angle and then removing the plug and pouring fluid in the transmission when it is off and cold. Good luck with that.
Aug 31, 2011 | BMW 330 Cars & Trucks
I have a BMW 330 ci 2001 the power steering fluid is low resulting in car being disabled. When I replace the fluid is therea reset process ?? Marjie H
There is no reset process, but the fluid may become aerated (foamy)when you start vehicle. The real issue is that the fluid leaked out, and that needs to be addressed.
Jun 25, 2010 | 2001 BMW 330
How do I remove xenon headlight unit on bmw e46
Just a thought, behind the front bumper are the securing hardware. Bumper needs to be removed so you can access the fasteners.
May 31, 2010 | 2003 BMW 330
BMW 318 ci coolant light comes on then goes off -
Remove the coolant level sensor and replace it.
Apr 20, 2017 | 2003 BMW Z4
Is there anthing special you need to do when fitting a new airflow meter for a bmw 330 ci coupe year 2000
Hello! The replacement of airflow sensor is simple on this model and requires no special procedure. Good luck and i hope i answered your question satisfaction!
Sep 17, 2009 | 2001 BMW 330
Computers & Internet Logo
261 people viewed this question
Alun Cox
David Payne
David Payne
