Question about KitchenAid KGRS807SSS Gas Kitchen Range
Gas oven dosen't maintain set temperture
When you start the oven, it rises to the set temp.  It reaches the set temp but it doesn't maintain the desired temperture. The read out says it's at the set temp but its not. Help.
  • 1 more comment
  • turbulance Oct 29, 2007
    Model # KGSS907SSS
  • Anonymous Mar 23, 2014
    and won't stop heating
  • Anonymous Mar 31, 2014
    oven dose not reach selected temp off by 100% is this a thermal cupler problem or a control panel problem and can I do the repairs
  • 290 Answers
My experience on the direct spark ranges is that the gas valve is usually at fault for this problem. The regulator valve and the burner shutoff solenoids are all built together in one valve assembely. The valve will work properly until it gets hot then it will stick and not open when the oven calls for heat again.
Please post back with the complete model and serial numbers if you need further help in troubleshooting it. There have been many updates and design changes on these ranges.
Thanks/Mike
Posted on Oct 29, 2007
  • Michael  Lindley
    Michael Lindley Oct 29, 2007
    Also, about the display. It doesn't display the actual oven temp after it reaches the set temp. It will stay at whatever you have it set at no matter what the actual temperature in the oven is.
  • Michael  Lindley
    Thanks for the model number.
    There are several different parts that have to work properly for the oven to ignite but the usual culprits for the problem you describe are the spark module and the gas valve. Usually when a spark module goes out it will quit lighting completely and also effect the surface ignitors also. Not always, but usually.
    If you want to go through the checks yourself and have a volt/ohm meter, there should be a tech sheet on the back of the oven that will describe the diagnostic checks and I will help you walk through them. If you just want to know what part needs to be replaced, I would tell you to replace the gas valve.
    Post back if you need further help.
    Thanks/mike
Oven heats up on preheat nut does not maintain temp for cooking
The older type stoves used a flue to maintain the temp. Later on we went to gas or electric heat.
Mercury based bulb mounted to a oven control maintained the flow of gas or shoctricity to the appliance. Todays modern kitchen appliance rely on thermistors to verify temps for the oven control.
A thermistor is a special resister that changes voltages. When the heat rises in the oven the voltage being sent out is messed with. These voltage drops are monitored by headquarters. The heat source is applied by judgement rendered from these measurements. In other words the control gets word and sends heat or don't send none. So what can go wrong? Sensor out of spec throws a monkey wrench in the works. That fancy smancy control yall paid big money fer don't know weather to well yall get the picture. The sensor used to measure temps in the oven is usually 1100 ohms at room temp. if it is off the oven will not work correct.
More Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 06, 2011 | Kitchen Ranges
Pilot light stays lit but oven will not stay lit
I would be interested to know just how long it is that the oven does stay lit. All ovens, gas and electric, cycle off and on throughout a baking cycle, to maintain the proper temp. If the flames or the power to the element were to stay on at full power for the life of the food's required time in the oven it would most likely wind up charred. The temp would simply continue to rise, up and up and up. If that's what it appears to be doing, then it's just working normally. If it goes out completely and stays off, doesn't come back on in a few minutes, then it may be in a keep warm mode. Many ranges have a TIMED BAKE cycle available, so you can set the clock to start the oven at such and such a time, cook the food and then shut off. Once it's finished with the cooking cycle, it goes into a keep warm mode, where it will come on for a short time and then go off, to maintain about 180 degrees. Not hot enough to really cook anything anymore, but hot enough to keep it warm for you when you get ready to eat.
If this seems to be the way it's acting, then look for the timed bake function on the console and set things back to a manual mode.
Apr 22, 2011 | Kitchen Ranges
I have an SL100 - 10W La Germania table top oven (gas) I did not receive a operations manual with purchase of the oven and I do not understand its operation. Questions 1. How does it maintain the set...
I GOT THE SAME QUESTION .. IT IS A GAS OVEN . WHEN THERMOSTAT IS SET TO GAS MARK 4 WHICH IS EQUIVALENT TO 350 DEGREES , AFTER 10 MINUTES, IT REACHES ITS DESIRED TEMP. BUT IF I DON'T ADJUST THE FLAME, THE TEMP WILL RISE HIGHER AND HOTTER THAT I NEED TO OPEN THE OVEN DOOR TO DECREASE THE TEMPERATURE INSIDE. ANYONE KNOWS IF THAT IS NORMAL? THANKS12_1_2012_3_54_19_am.jpg
Oct 26, 2010 | Ovens
Mer5755 Oven losses temp. Start at 400 loses temp later
The problem is usually the ignitor not reaching the correct amp draw .When the ignitor does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The ignitor are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available.
Apr 02, 2010 | Maytag MER5755Q CleanDesign Electric...
Oven does not maintain a consistent temperature
Is this oven gas or electric? If it is gas then it can be normal to see 30 to 50 degrees difference in tempature. The tempature in a gas oven works on the average tempature. For example: The oven tempature may rise all the way up to 370 degrees. Then the burner will shut off. And then the tempature can drop all the way to 330 degrees. Then take 330 and add that to 370 then divide that number by two and the average tempature will be 350. If your oven is electric then the tempature should be much more consistant but can have a 10 to 15 degree variance. Also the standard oven tempature guage that you put in the oven or even the temp guage built into the oven are not very accurate. We us a Fluke meter with a thermocouple to calibrate an oven. So to check your oven for proper tempature regulation you will first need to let the oven pre-heat for about 15 minutes. Then place the thermocouple in the center of the oven. If the oven is electric the take a temp reading every 5 minutes and average them out. If the oven is gas then you will need to take a temp reading when the tempature reaches it's highest and lowest points. Take at least 5 consectutive readings and average them out. You should get an average within 10 degrees of set temp(350 degrees). If it is off by 35 degrees or less you can usually caluibrate the thermostat back to proper temp. This procedure can be different for each range model. If it is more than 35 degrees off or you are getting irratic readings then the thermostat or thermostat components might need to be replaced.
Mar 16, 2010 | Kitchen Ranges
GE Xl44 does not reach or maintain setpoint . Display indicates increases of 5 degrees/second, but temp is not reached or maintained.
Have your oven ignitor checked. If they do not get hot enough quick enough the oven will light intermit. Usually when it does light you will often get a scent of gas or a poof. If that's the case, change the ignitor
Sep 11, 2009 | GE Spectra JGBP35 Gas Kitchen Range
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
Oven does not maintain temp.
It sounds like a thermocouple problem. While using the broiler, you gave the gas set to full and the thermostat is basically out of the loop.
Feb 20, 2009 | Frigidaire FGF316 Gas Kitchen Range
KitchenAid KGRS807SSS Gas Kitchen Range Logo
347 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
