So I try different sim card but problem still same when I remove and keep without sim card its work nicely with wifi that all.
SOURCE: cellular phone doesnt recognize SIM after it got wet
dear it happen when mostly connection of sim module is cut of check the connection.
SOURCE: sim card not working sim works in other phone
The first thing you can do if you think there is aproblem with the phone settings is that :
Go into network setings of the phone and choose MANUAL in the Network selection. Then you can search for the Lebara network manually and select it, if it works.
Or if it doesnt work, then the phone probably might have been locked. Just check it once, using any other network simcards it your phone. If it is locked, you can easily get it unlocked in your local market.
SOURCE: I have a new Samsung
Hi.
Please try dialling one of the Samsung secret security codes listed below. The operation will reset the phone removing the lock. Test with and without SIM. After reset the phone will be unlocked entering the default code 0000:
*2767*3855# (full reset)
*2767*2878# (custom reset)
Here the full list of Samsung secret codes.
Note: Samsung secret code will not unlock the SIM lock, SIM PIN or PUK code.
Regards.
Ginko.
