Question about Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Sharp 27DV-S100 - DVD tray stuck and open unit?
Funny story - but need a better ending: I banged my head on the open DVD disk tray - now it will not close - it opens a bit when I push "OPEN" and closes a bit when I push "PLAY".  I believe the problem is that I pushed the tray off the track and gear and the tray skipped and comes out too far, so now when the tray tries to go back in, the reader (?) inside pops up too early and will not allow for the disc tray to close...I have tried to open the television as I have loosened all the screws on the front panels and removed them - however, I still cannot get the panel off the front of the televison (the entire front section: the problem is the bottom portion does not seem to budge - is there a trick further than removing all the obvious screws?
  • Anonymous Apr 26, 2009
    I have a stuck tray for a Toshiba DVD/TV combo...possibly due to a DVD inside. Haven't succeeded in getting front off yet either as some screws are too recessed to get at with standard screwdriver. However, I noted there are tab locks on the bottom of the TV. These plastic or metal pieces may not be obvious but look like they need to be pressed in to release case.
5 Suggested Answers
SOURCE:
techman
  • 3130 Answers
SOURCE: Can't Get Any TV picture on mySharp 27DV-S100 TV-VCR-DVD combo
open back up the set and look closly at all of the plug connections and cables as you might not have pulled one out all the way but may have in inadvertantly pulled on a cable of one of them and pulled one out have way or just a little. My freind it happens to the professionals all the time. Make sure you check all the plugs on the VCR as well as the tv that they are instraight and flush. Good Luck Ps Please dont forget to rate this.
Posted on Oct 15, 2006
ctf1800
  • 4402 Answers
SOURCE: sharp VT-51DV30 ....combo tv/vcr/dvd
unplug the unit and plug it back in see if it resets
Posted on Dec 03, 2007
mbelectronic
  • 147 Answers
SOURCE: My Sharp 27DV-S100 will not accept DVD discs.
replace the dvd mechanism assembly.usually
runs 60-90 bucks.you can buy the part from
encompass.com.the dvd mech cannot be repaired by individual parts.the entire dvd mech
must be changed and is available.this may
require a technician to repair this depending on
how mechanically inclined you are.the part is
available to the public.
Posted on Jul 29, 2009
  • 945 Answers
SOURCE: There is a DVD stuck in the DVD player. The player
Ok try the below:-
http://www.ehow.com/how_2054298_remove-dvd-stuck-player.html
Posted on Nov 05, 2009
I burned a movie on a +R DVD. It plays on my computer but not my Mintek DVD payer. Why is that?
computer disks are different then DVDs. you probably burned on DVR format. you can get a converter and make sure the file on the disk is AVI or, DVD
Sep 20, 2013 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
How to restore my closed caption
Go into the setup menu and select whichever cc mode you want.
Dec 13, 2012 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Wake up light flashes three times but wont turn on
faulty power board either try replacing it or replacing all the capacitors on the board
Nov 09, 2012 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
I have a vertical black line on sharp lc-52xd1e is this dead pixels?
It means an addressing transistor for one column of pixels is dead. It can probably be repaired. It would be statistically unlikely for more than a couple of pixels to die over the lifetime of a set.
Oct 10, 2009 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Jul 29, 2009 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
DVD will not eject DVD
I just had that same problem. i tried turning the tv off and then but didn't work. What worked for me was tu unplugged the power chord from the outlet, wait for 5 seconds, then replugged it, turn the tv on and while it's turning on open the dvd tray. It should open without problem. At least it worked for me.
Dec 26, 2006 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Oct 15, 2006 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Sharp 27DV-S100 27 in. TV/VCR/DVD Combo Logo
71 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
