I have a one handle Moen shower with a push button diverter that is under the handle. The push button totally broke off (has a jagged end) It shot out of the face plate while taking a shower and water shoots out of the hole. I tried to fix this by putting in a tub diverter spout, it does briefly divert the water to the shower head,then the old push button shoots out again along with water. Is there a way I can just plug the hole?
SOURCE: Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
SOURCE: shower diverter push handle is squirting water out
If you are handy, the best solution is to call delta and have them send you a new diverter. They will need the model of your faucet. The new diverter will come with instructions on the install process. As far as fixing it without the new diverter, I don't believe you will be able to.
SOURCE: leaking shower/tub faucet, looking for replacement
Call Moen directly. They will ship what you need to your door, for free.
