Question about Refrigerators
Warm fridge I have a 10 yr old crosley 17 cu' refer with no freezer & it wont get below 45-50 degrees mod # is wcr17-zw/c
  • Dave Manley Oct 31, 2007
    I can see no fans , fins or metal grid - under behind or inside .  There is only a small compressor under & behind & a " cooling "? element inside top ( where the freezer would normally be ) I did find a small hole in the cooling element at the end of its  "coil"  also the unit can get frosty when i unplug it & replug , but within 15 min it's back to 45 degrees .  I plugged the hole & got pretty much same results !   Does it lose freon through that hole or is that an overflow ??
  • Refrigerators Master
  • 4,655 Answers
Can you check to see if dust has accumulated under the refrigerator and the fan under the refrigerator is blowing warm air?
If the fan is blowing correctly and you find dust blocking the condenser area beneath the fridge try to blow it out or vacuum it away from the fins or metal grid. Just a small amount of dust there or a leaking door gasket will make it hard for the refrigerator to cool properly. Also check that nothing has blocked the entrance or the exit of the condenser warm air area. Hope I have helped you today, Thanks Sea Breeze
Posted on Oct 29, 2007
  • John Tripp
    John Tripp Oct 31, 2007
    Some refrigerators put the heat exchanger on the back or like some those you see now called dorm fridge the heat exchanger is placed inside the outside walls and as it cools inside the heat is passed through the outside walls. I tried to find a good view of yours and found only a crosley sales link and think I see a current model similar to yours called the All Refrigerator. I'll put the link below. Click below-----http://www.crosley.com/products/kitchen/...**.app1
    The small hole in the element you see will affect the cooling, and the remaining freon will need removed the hole sealed with good epoxy put in the hole, a vacuum for about hour and recharged by someone that is good with refrigerators. Hope this helps, Sea Breeze
How cold should the freezer get?
I am assuming you are referring to Fahrenheit.. 16 is a little warm for a freezer. They usually stay around zero to 10 degrees above or below.
Sep 14, 2014 | Samsung Refrigerators
On my GE GTH21SCXSS, top freezer bottom refer, the freezer and refrigerator settings are on the coldest settings and the freezer won't go below 15 degrees and the refer won't go below 43 degre
Do you see any ice buildup on the back panel of the freezer? You may need to remove the back panel to see if the coils are iced over. Post back your results.
Feb 10, 2013 | GE GTH21SCXSS Stainless Steel (21 cu ft)...
Hi, my admiral side by side fridge is having problems. The freezer is working fine but the fridge is not cooling. I noticed 2 days ago that the temperature indicator for fridge was bleeping at 4 degrees. I...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Admiral 26 cu. ft. Side-By-Side...
Amana bottommount refigerator--ABB1922FEW--- BUY 08-03-07 AMANA REFIGERATOR WARM---60+ DEGREES FREEZER ---YES---10 DEGREES FREDD- APHASIA--COMMUNICATION PROBLEMS--- NICKNAME: giesslerf PASSWORD: abd7f
Wow
Ican not understand what you need.
So I am guessing here
Ice has built up on the evaporator coil stopping air flow to the food section.
Try manually defrosting the fridge. If this works then the auto defrost cycle has failed and you will need to get a technician to help you
Mar 30, 2011 | Amana ABB1922FEW (186 cu ft) Bottom...
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
True t-49 Freezer not getting below 10 degrees
is his garage as hot as yours?
Be sure the condenser coil is real clean. Best place to start. Freon levels, door seals are another place to look.
Let me know if I can help any further.
Jun 26, 2010 | True 52 cu. ft. / 1472 liter Commercial...
Gladiator fridge/freezer-freezer not cold enough, stays at 10 deg
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Dec 12, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
1 yr old Kenmore fridge (18 cu ft top freezer mdl 970-41924) has very long defrost cycle - freezer contents partially melt, fridge warms to 50-55 F. (Normally runs at 38-40 F.) We keep several litres of...
Either the defrost timer is going out or it could be your defrost bimetal thermostat that is located behind the back wall in your freezer. Both parts are cheap and easy to install. I would replace both.
Sep 09, 2009 | Kenmore Refrigerators
Fridge does not cool below 40 degrees
This is a common problem and a design fault...
Jun 25, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerators Logo
431 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
