Question about GE GSL25JFPBS Side by Side Refrigerator
Constant clicking from freezer fan that won't start
Constant clicking sound from fan in freezer and the fan will not completely start.  Never actually hear the compressor start either.  There is also a green wire behind the plastic light cover in the freezer that has a metal clip but nowhere to connect it to?  Has done this several days and sometimes is able to start.  Have unplugged several times but problem persists.  Looked at computer board but afraid to touch it!
  • 3 more comments
  • mccutcheon Oct 28, 2007
    No ice on fan but thanks for reply
  • mccutcheon Nov 01, 2007
    Now I have found that I can lift the cover over the freezer fan and manually start the fan, but this can't be safe for a girl!
    ......and I don't know anything about the defrost cycle
  • Anonymous Jan 10, 2008
    fan and compressor clicks but wont turn on
  • limclaughlin Aug 08, 2008
    Hi, I have the same problem. My water & ice dispensers are not working and the fan is making a clicking noise (like it's trying to turn). Any advice?
Could be the defrost cycle is not running properly and the fan has ice on it.
Posted on Oct 28, 2007
GB2SHDXPS01 FAN RUNS CONSTANT, FREEZER ICES UP
Buy a used fridge on ebay, they are very cheap.
Dec 21, 2013 | Whirlpool GB2SHDXP Bottom Freezer...
My fridge upper unit isnt working, there is no air circulating, i could hear the compressor working and it seems the lower unit is fine. it started by making a constant ticking sound and then a day later,...
You will need to look into the possible chance that your evaporator Fan motor has stopped, been damaged or the freezer is not defrosting properly. To allow it to continue running can damage the compressor. Click Here=> MFD2560HES Evaporator Components then 12002744 Evaporator Fan Motor and again the 67002493 Defrost Heater I have all the instructions and hands on if you would like my assistance I will be here to assist and repair you Maytag That ticking noise could have been your fan blade finally reaching the frost until the fan stopped. Let me know Here or or here on Fixya, Thanks, Sea Breeze
Sep 14, 2011 | Maytag MFD2560HES Bottom Freezer French...
FRIDGE AND FREEZER DO NOT COOL. FAN AND COMPRESSOR ARE RUNNING AND AIR IS FLOWING THREW THE VENTS BUT A WIERD NOISE APPEARS EVERY 2-3 MINUTES LIKE THE COMPRESSOR WANTS TO START BUT IS RUNNING STILL. ...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
also are the coils clean?
Feb 26, 2011 | Maytag MBB1956GES Bottom Freezer...
I have a Kenmore model 596.79272990 refrigerator that has stopped cooling in the top box. Freezer is still cooling but have some internal condensation that is not freezing. The freezer fan does not...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 17, 2011 | Refrigerators
The freezer acts as if it is going to start, but then it doesn't. the fan inside is running, but the temp is up to over 40 degrees
When a compressor is burned out it will try to start and then quickly overheat and kick out on the safety. Listen closely to the fans when the compressor tries to start. A bad compressor will pull so many amps that the fans will actually slow down until you hear the click, then the fans will pick up speed again. If this is the case you will need a replacement compressor. Let me know how long it takes to click out when it tries to start.
Sep 15, 2010 | Traulsen 46 cu. ft. Commercial Freezer...
I come home and water is on the floor due to my freezer not working. I think its a condenser problem; so I vaccum out my condenser coil and restart the condenser fan. But the condenser is still making an...
check that compressor is running. if your hearing a hum and then click you probably have a faulty compressor relay. most times you can pull it off and shake it and you will hear little bits rattle, well it should actually make no sound. but it could still be bad if compressor fails to run. compressor may or may not be warm.
Jan 21, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
CONSTANT CLICKING SOUND COMING FROM POWER BOX
if the fan blade is contacting anthing under there and stops it will shut down the compressor and wont work
Aug 23, 2009 | Refrigerators
I have a 10 yr old Maytag side-by-side. Came home the other night and the Freezer was at 40F. What is the most likely problem
to start: make sure refrig is turned on and running.
1.do you hear the fan blowing inside the frzr compartment?
2.pull refrig out and listen for compressor running. is compressor running/humming away or are you hearing a humming sound followed by a clicking sound?if you hearing a clicking sound than mostly
is your relay on the compressor that went out. look for a smal device on the side of compressor w/two or three wires. part# 12002794 $32.00
also make sure there's no frost build on frzr rear wall.that's another problem
Jul 15, 2009 | Maytag MSD2758GEW
Frig. and Freezer not cooling. Clicking sounds heard every 2 mins
sure sounds as if it is def a compressor overheating, now that the compressoe will be cooled it should work , but your right damage may be already done, the good news if any is that you should be covered under 5yr manufactures warr for compressor
Dec 22, 2008 | Maytag MTF2155GRW Top Freezer Refrigerator
GE GSL25JFPBS Side by Side Refrigerator Logo
163 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Brad Goodale
