Home | Rancilio | Silvia Espresso Machine | Flow through head too...
Rancilio Silvia Espresso Machine
Problem for Rancilio Silvia Espresso Machine
Flow through head too fast
By broberson28 on Jun 10, 2009
I have tried 2 different grinders and pack the coffee very hard but still the flow through the head is too fast
Solution #1
posted on Jun 10, 2009
Not Rated)
bansheracer
Rank: Guru  Kitchen Appliances  Expert
Rating: 91%, 149 votes
HI When you grind your coffee, try to pinch the coffee between your fingers. If it sticks to one finger and forms an impression of your fingers, that's good. If it doesn't, then your grounds are not fine enough. Fresh beans also is a must. Don't use the single basket because thay don't work that well. Fill the basket level with ground coffee, then tap the portafilter on something hard to settle the coffee. Then do your tamp, with about 30 psi pressure. Wipe the lip of the portafilter before you insert it in the brew head. then do your brew. You should not get any drops for about 5 seconds after you turn on the switch. then it should just drip a little, then you should get a mouse tail from the spouts. You are shooting for a 1 1/2 oz. to 2 oz in about 30 seconds. No more than 2 ozs from a double shot basket. Add water if you want more.
Was this helpful?
Yes
No
Popular Solutions for Rancilio Silvia Espresso
Questions and Unsolved Problems for Rancilio Silvia Espresso
Do you recommend Rancilio Silvia Espresso Machine?
Answer
Answer
Hi, last week I purchased the Rancilio Silvia Espresso Machine. For most of this time I have been... (More)
Answer
I have a Rancilio Silvia about 2 years old. About 10 days ago I did a descale and backflush process,... (More)
Answer
bad check valve in rancillio silvia? pressure loss thru group head while steaming
Answer
I am trying to use my Rancilio Sylvia for first time and the steam knob is stuck.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Rancilio Silvia Espresso...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
