SOURCE: samsung e-250 i need unlock code
Please follow the instructions carefully! Following are the 12-point instructions to unlock your Samsung E250 phone:
1. First do a CUSTOM RESET by tying in:
*2767*2878#
(Phone may display foreign language – don't worry! The last digits after the * will appear as - - - -; this is normal)
2. Turn off your phone
3. Take the battery and SIM out of the phone
4. Take a wrong network SIM (a SIM the phone does not currently accept) and insert it ONLY HALF way in, so when you turn on the phone it won't detect the SIM. Very important so the phone won't ask for network password and will show "Insert SIM" message.
The process of inserting only half of the SIM. I advice you to take care and do it with a soft approach as you might not have done this before.
5. 2. Now put the battery in carfully behind the protruding SIM card and switch the phone on. The phone must show "Insert SIM" message.
6. 3. Without turning off the phone, now push the SIM card all the way in, at this stage the phone must continue to display the "Insert SIM" message with the WRONG SIM inside.
7. Now make a FULL RESET by typing: *2767*3855#
9. Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
8. The phone should reboot working with "wrong" SIM inside. (Do not turn off the phone)
10. Disable network lock by typing: #7465625*638*00000000#
12. Check this is done with *#7465625#
If your phone is not unlocked please retry the above ensuring all steps are followed to the letter, 9 out of 10 people who have problems have made a simple error and find that when they repeat all the steps it works.
SOURCE: I want the code to unlock my Samsung F480T from
i have a samsung phone from a friend but i have to unfreeze it then unlocked it
MODEL:SGH-F480T
SSN: F480TGSMH
IMEI: 358090/03/053689/9
Unlocking helps to remove the network lock..So that you can use with other GSM Network sim card in it.IMEI Number is Unique for every mobile..IMEI means International Mobile Equipment identity.Using the IMEI you can identify the mobile phone model...It's unique for every phone.It will not same...While Unlocking you need to specify the brand ,model ,network,country it's locked now ,IMEI number
S/N is RF1C57WBP7B
is serial number..
You can get the Unlock code for SAMSUNG E1190 model Phone at
Classicunlocking.com/samsung-e1190/rs17wp9/ and Unlock it from Vodafone network lock..Then use with Telstra Australia or any gsm network from any Countries.
You may contact your network provider Samsung S5603T Unlock Code. I suggest you to visit Samsung Unlock Code site, they will provide
you with an accurate code fast with easy to follow instructions on how to
unlock your phone. Once your phone is unlocked, it will work with any network
worldwide and don't have to stick to one network.
Hope this is helpful.
Thanks.
