Question about Eddie Bauer Lightweight Travel System 01-750-AFD
Canopy I took the 2 scerws off, but the canopy is still attached and won't come off. There is another bar that is attached to the canopy. How do I get that off?
  • sherri69 Jan 05, 2008
    same problem.. argh
  • 4 Answers
What I would do is try to find a way to completely detach it bars and all. they hand wash the whole thing...bars and all in the bath tub or something. This is what I did with my eddie bauer tandom stroller (worked like a charm)
Posted on Feb 18, 2008
I have a Bugaboo frog. I accidentally broke the piece that attaches the canopy to the frame, on one side. What do I do now?
if it's within 2 years old it's covered.
Call toll free: image_gallery?uuid=6a479f2d-8718-40f4-b775-292deedb9bd4&groupid=10136&t=1318502576820 800.460.2922
Email : serviceus@bugaboo.com
Fax: 310.496.0988
Hours: Mon-Fri: 10am-7pm EST
http://www.bugaboo.com/all-products
Sep 06, 2012 | Bugaboo Frog - Blue Stroller
I lost instructions for my Avid Outdoors screen gazebo model #2086 13'x9'. Any help is appreciated
avid outdoor doesn't offer instructions...can someone please post instructions for some of these...it would really be helpful...its crazy that some of these boxes dont come with instructions?!
Jul 18, 2011 | Garden
Hi I have removed the sun canopy from my maxi cosi cabriofix car seat so that it could be washed but I now cant re-attach, can you please advise? Thanks
Good Afternoon
There are two hoops of elastic at either end of the sun canopy - these hook in behind the knuckles of the bar that goes over the carseat (the carry handle/roll bar). Once you've hooked them in (it is fiddly, but possible) you can then tuck the rest of the fabric in between the plastic at the back of the carseat and the carseat fabric.
If you can't do it, pop it into a local retailer and ask them to give you a hand.
Jun 03, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I need assembly instructions for disney princess
Use the hardware that comes with the Disney Princess canopy package to install the main canopy hook in your ceiling. Center the steel ceiling hook above the center of the twin bed and screw it into the ceiling by hand or with pliers. 2 Follow the included instructions and insert the four poles into the sleeves of the canopy. The two longer poles will run lengthwise above the bed, while the two shorter pieces will run widthwise above the bed. 3 Attach the canopy to the ceiling hook by slipping the plastic ring of the canopy onto the hook. The four polyester sides of the canopy should now hang over the twin bed. 4 Use the customer support form through the Exxel Outdoors website if you have questions regarding your Disney Princess canopy.
  • Jul 10, 2010 | Princess International Nursery Crib Bed...
    Dismantleing canopy
    If this is for the Graco Snugride (I have the Windsor model from the Quattro Travel System), this will work:
    1. Push the Graco canopy to one side, exposing the plastic support bars that hold the canopy in place.
    2. The center of the support is where the canopy comes apart. Using both hands, pull the canopy support
    bar apart (as if you were playing tug-of-war). It's best to grab the curved ends and pull HARD (and point it away to the side so that you don't hit your face).
    3. Once the support bars are apart, remove the old Graco canopy and slip on the new/freshly washed canopy.
    4. Secure the support bars by snapping them shut, and then slide the canopy into place.
    Aug 26, 2008 | Graco SnugRide - Clover
    How to attatch parasol
    You can attach the parasol to the front bar or to the sides of the seat frame. You would attach it like you would attach the cup holder or the canopy clamps.
    Jun 25, 2008 | Bugaboo Frog - Aubergine Stroller
    Eddie Bauer Travel System - Removable Hood??
    Took me awhile to figure this one out...
    There are two bars attaching this hood to the stroller. The rop bar is obvious and removed by taking out 2 phillips head screwdrivers.
    The bottom bar seems much more tricky as it seems "permanent".
    Upon closer inspection, the lower metal "hood bar" goes into the side of a round clip. This round clip has a button snap in the middle of it. This round clip can be removed by pulling on it (not intuitive at all). It is not bolted on. It turns out it only encircles the metal bar it is attached to 3/4 of the way like a c-clip and will stretch to come off. You cannot remove the bar from inside the hood, but you can toss it all in the washer! Good luck!
    May 24, 2008 | Eddie Bauer Lightweight Travel System...
    The sun shade on top
    1. Infant restraint comes with four identical canopy support parts. Thread one canopy support completely through one sewn tunnel.
    2. Slide straight end of a second support into the straight end of the first support.
    3. On models with four canopy supports, repeat steps one and two for the other canopy tunnel.
    4. Attach canopy in the areas between the infant restraint and the handle base.
    To remove canopy, reverse the steps.
    http://www.gracobaby.com/assets/pdfs/instructions/ISPC089BA_ISPC106AA.pdf
    Hope this helps!! Thanks
    Nov 16, 2007 | Graco SnugRide 8646 - Fiesta
    TAKING OFF THE CANOPY
    There are two tiny screws on each side of bar the the canopy is wrapped around. Unscrew them and you will able to slide it right off!
    Oct 26, 2007 | Eddie Bauer Lightweight Travel System...
    Eddie Bauer Lightweight Travel System 01-750-AFD Logo
    356 people viewed this question
    Top Eddie Bauer Baby Gear Experts
    Jennifer Rock
    Jennifer Rock
    Nikki  Mclean
    Nikki Mclean
    Douglas Dinnebeil
    Douglas Dinnebeil
    Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
