Question about Canon PIXMA MP510 All-In-One InkJet Printer
Paper jam when i got my mp510 printer it was working fine until the bottom feeder kept getting the paper jammed in it so i used the top one and a few months later the top does the same thing its like a part of the paper wont roll in making it fold and jammed any one know how to solve this
    Scholar:
  • 121 Answers
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers.  See if the rollers will turn manually, but be careful not to force anything.  Another way to get to the whole roller, would be to start making a print, while watching the rollers.  As soon as the rollers have turned half way, unplug the printer.  Now you can reach the other side and clean that.
There is another way to clean the rollers.  Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution.  Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine.  Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Posted on Oct 28, 2007
Paper does not feed from top of my hp 7210 printer and can not fax from top feeder. I can not use the top feeder to copy multiple documents. Only bottom feeder works. When I have to fax something, I have...
The rollers on the feeder can go bad and the best way to solve it is to get a new complete assembly. Check the website under your make and model for the assembly. YOu might also want to check for paper jam
Mar 19, 2011 | HP Officejet 7210 All-In-One InkJet...
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Paper feeder not working
That printer has a feed switch which changes from the top feeder to the drawer below, the little light tells you whether to put paper in the top or bottom. either make sure both are loaded or switch to the one that has paper.
Sep 24, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Hi, While loading paper I'm getting an alarm saying E2 though papers are present in the paper tray. I 've pulled the clip in the paper feeder to the left, kept the paper i.e. alligned it to the right of...
Does your printer have a paper tray on the bottom as well? If so there's a feed switch that tells your machine to use the tray or the rear feeder. There's also a small printer picture with a light that either is lit for the top or bottom feeder. To be safe, put paper in both trays.
Aug 13, 2009 | Office Equipment & Supplies
Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
Jun 21, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Problems with paper feeder-wont feed through-chews up paper
I HAD THE SAME PROBLEM A MONTH AGO. I LOOKED WHERE THE PAPER LOADS AND THERE WAS A PAPER CLIP JAMMED IN THERE. I HAD A HECK OF A TIME GETTING TO IT, BUT I DID. AND IT WORKS FINE. MAYBE SOMETHING IS THERE.
Jan 31, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Officejet 7310
Sounds like there is something going on with the paper sensor flag that resides in the top cover of the automatic document feeder. Need to make sure it is moving freely. It is spring loaded so it should move freely and spring back in to place. Sounds like your may be sticking in the up position after a few sheets. When the ADF lid is down these sensor flags should go in to holes in the bottom of the ADF. Hope this helps..
Inkworks
May 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Paper jam
After changing my blank ink tank, I have the same problem. Finally discovered that it was not fully clinked in. Once it was push in till it clicked as per instructions, the printer is printing beautifully once more.
Dec 06, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Printer
Have you tried switching your printer to load from the back feeder using the feed switch button?
Oct 30, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Printer pulling on paper
My husband took the top cover off the printer and took a good look inside with a flashlight. He found a hot pink crayon stuck where the paper feeds through. I guess I should have had a better look initially, since the paper never made it all the way through the printer. Works like a charm now!!
Feb 23, 2007 | Lexmark X6150 All-In-One InkJet Printer
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
204 people viewed this question
old marine
old marine
