Question about Averatec 6200H Notebook
Just died It got really hot and then just shut off, 1 week later tried it again and it came on and then did the same thing. Now I can't even get it to come on. It has an amber light present but that is it.
    Problem Solver:
  • 5 Answers
Mabey a component on the motherboard has been burnt out.
ask a computer technician
Posted on Oct 28, 2007
Gateway 6920
The dying hdd cause some problems. Replace the hdd.
Feb 21, 2014 | Computers & Internet
Our 2007 Jeep Grand Cherokee randomly won't start.
change the wires that go to the starter i had the same problem fixed now with no problems
Jun 20, 2012 | 2005 Jeep Grand Cherokee
Acer aspire one netbook A0751h-1346.Kept shuyting down even after charging .turn on it would turn off and now there is no power unable to turn on.Is it battery adapter or a driver issue.please help...
Ive seen this problem recently. It was the battery dying. Basically the pc needs a small amount of power from the battery, even when plugged into the mains.
Get a cheap one from ebay, $25.
Sep 11, 2010 | Acer Aspire One PC Notebook
Nissan Sentra random stalls and wont start hot
Check out the catalytic converter, might be plugged up. I have seen some cars that will run fine, and like someone threw a switch the car acted like yours, no power, would not rev and died. Later when cold they would be OK for a while then just get worse and worse.
Jul 03, 2009 | 2001 Nissan Sentra
2 weeks ago one of my units stopped working properly. It got warm during the night even though I heard the unit running. I shut it off and called for repair service. They changed the thermostat and it...
sounds like the coils inside the air handler/furnace are freezing up. likely cause is the freon charge is incorrect (probably undercharged). it may have been correct when the tech did the work but some may have leaked out. it is slightly possible too that the system is overcharged. you should have the system pressure verified, and then have it checked for leaks.
Jun 16, 2009 | Goodman CLJ36AR42 Air Conditioner
2002 Cadillac DeVille wont start (even w/new battery!)
well first off, check the glove box light blub, make sure it shuts off when you close the door, check it by pressing the switch with your finger to make sure it shuts off, also check under the hood for the light there if there is one, pull the bulb, and the same thing for any bulb in the trunk, then check again after a day to see if the battery dies, if it is dying while the vehicle is not running then it is the battery, if it is dying after it is running then it is the alt. you can check that also tho with a multimeter set to the DC volts setting, place the black end <the ground to any grounded area> and the red end <the hot lead to the back of the alt. > it should be reading higher then 12 volts, normally should be a higher reading then 12 volts... if you are getting a lower reading or just 12 volts then the alt. is bad and needs to be replaced...hope this helps you out...
Jun 14, 2009 | 2002 Cadillac Deville
2003 town and country brake problem
Did your mechanic use a DRB III or equivalent scanner before performing the bleeding procedure after installing the master cylinder? This is a requirement by the manufacturer (Chrysler) when bleeding the brake system.
Jan 16, 2009 | 2003 Chrysler Town & Country
BAD BUICK
chahge the battery, it is loosing charge.
Aug 14, 2008 | 1994 Buick LeSabre
Dodge ram van e250 dies while driving
try changing the coil- sometimes they get hot and break down- once they cool off vehicle will start and run until they get hot again
Jul 05, 2008 | 1992 Dodge Ram 250
Maytag Over the Range Microwave
Assuming the entire power line from the breaker to the microwave cord is okay, it's almost certainly a bad connection on the circuit board of the control panel assembly. For reference, we repair these from all over the country for $32.50 postpaid.
Oct 16, 2006 | Maytag MMV4205 Microwave Oven
Averatec 6200H Notebook Logo
26 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
