Question about Mitsubishi VS-5043/44 50" Rear Projection Television
Rear Projection 40PW03B
This T.V is 6 years old, the problem started when it switched itself off after a while of being on, now it won't switch on at all.
Hi Solaron,
I've tried replacing the 5A fuse but that didn't have any effect.
How should I go about fixing the switching transformer?
Posted on Jan 09, 2008
I found that the main 5A fuse was blown. After replacing it, the set worked for about 1/2 hour and the problem really was the "switching transformer had a shorted winding.
Posted on Dec 16, 2007
My sony KP-443X3U rear projection tv went to standby and I cannot get it to switch on. It is approx 6 years old. I think the bulb needs to be replaced?
Google the model number to locate it with "lamp" and You Tube has video instructions for replacing in most models--lamp has a 2,000 hour or 2 year average life and is meant to be replaceable by the customer who owns the set.
Nov 06, 2012 | Sony Televison & Video
Panasonic PT-51G50CU
HEY !!
ITS A CIRCUIT BOARD PROBLEM ... IC MAY HAVE BLOWN OFF ...
Jan 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
We have a 6 year old tv. We are starting to see
hello,
If your problem like pict below :
(worst dot's on screen)
Change the DMD.
Good luck.
Mar 23, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
My 10 year old 55 inch Mitsubishi rear projection shuts off.
The main board/switch is worn to the point it will not work anymore after a while, I been in the business for years, These are wonderful TV's, yes there are replacement parts but a quick fix your looking for here will be unsuccessful this is the reason I am providing my advice and take a chance on the rating your going to give me. Try www.ebay.com look for people that is saling parts for these TV's.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 03, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Power issue
No picture on my Magnavox Big TV RJ8530 S/N 61998120
Aug 06, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Toshiba 40pw03b stuck on standby
the red light comes on and off tv dont work
Jul 28, 2008 | Toshiba 40H80 40" Rear Projection...
Hd50lpw175x7
Ballast Verification Process
1. Short out door switch (SP001)
2. Apply AC power and wait till DM module boots
3. Press power switch and observe spark gap on ballast
4. If spark gap arcs, suspect Lamp. If color wheel starts but ballast won’t strike
lamp, go to next step.
5. Measure BP252 on AC IN CBA for +300Vdc. If missing check door switch, cable
from AC IN CBA to switch and AC IN PCB. If correct go to next step.
6. Monitor pin 2 of BT251 for Ballast ON command from Light Engine. If present
suspect Ballast. If missing suspect Light Engine. Pin 5 of BT251 starts at 3.3V
after power switch is pressed and drops to .18V when the Light Engine sends the
start command. No change on pin 5 indicates Light Engine is suspect, change
on pin 5 with no ballast start, ballast is suspect.
Note: Lamp may arc but not start. Pin 5 of BT251 is "LAMP LIT" and goes to 1.48V
when lamp is lit. If ballast strikes lamp but lamp won’t stay lit, suspect Lamp.
Jun 09, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Samsung rear projection problem
sounds like you may need a new lamp.about 150.00 to 200.00$
Jan 19, 2008 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
