Hi i am using grand cheeroky 95 v8 wile iam driving its ok but if i stop and the AC is runing the car will become overheat i checked the fan is working nice could u solve my problam
hi i have grand cheerokee 1995 v8 and the temp is 210 to 240 with AC is it normal if not what is it.i replaced the thermoster and the fan is quite nice working so what it could be .plzzzzzzzzzzzz some body help meeeeeehi i have grand cheerokee 1995 v8 and the temp is 210 to 240 with AC is it normal if not what is it.i replaced the thermoster and the fan is quite nice working so what it could be .plzzzzzzzzzzzz some body help meeeeee
You can't post conmments that contain an email address.
Could be but I would get it checked. There could be an air pocket in the cooling system, sticking thermostat, fans not working or water pump not pumping efficiently. Overheating can cause blow headgaskets, cracked head or blown engine all of which are very expensive to fix.
hi
there is no recall from jeep (there should be) your blend doors are damaged or broken. jeep will quote you around £800 to fix. log on to heatertreater.net they have a diy quick fix that will last the life of jeep. you can install the new blend doors that are metel (not stupid plastic ones jeep use) in around half an hour, this really does work as i have installed a few of these kits with no problems.
hope this helps
does it have an electrict fan? if it does is it working?
if it doesnt the problem is prob the water pump and you also prob need too flush the system!!!!!!
when the ac is on the computer is looking at pressure in the ac system to control the cooling fan operation if the pressure is increasing the cooling fan is commanded on now if the pressure switch is bad or if the ac system is low on refrigerant it is not building pressure and the cooling fans are not going to come on.
