Question about Quasar SP-3233 TV
Sometimes no picture on RCA tv
Sometimes my standard 31" RCA tv has a black screen when turned on.  Then the picture appears after a few minutes and is fine for the rest of the day.  Other times the picture is fine when the tv is turned on.  Sometimes the picture is fine and goes black for 5 minutes or so, then comes back on.  What's going on?  Thanks.
  • 4 Answers
Its nothing really, if your tv is new then it is normal but if it continued to do it then its broken
Posted on Oct 15, 2008
My rca truflat tv will get a black box pop up on the screen. It covers most of the picture. Sometimes there will be text in the box. If I adjust the volume it will disappear for a few seconds then come...
It is a Text or Description box that operates like Closed Captions. Cycle through the options by pressing the Caption button on the remote or go to the Caption menu and turn it off.
Jan 17, 2010 | RCA TruFlat 27F520T 27" TV
Unwanted rectangular black area appears on screen blocking 40% of picture
This could be the result of a partly shorted vertical winding on the deflection yoak.Since the line is on an angle and not straight across.
Nov 07, 2008 | Durabrand DWT1304 13" TV
Scattered black lines appear then screen gos black, but still have good volume
Hello 4fiddy,
You have actually diagnosed your own problem, Let me explain; the line "I can slap the left side of the tv and picture will almost always come back on" This indicate some form of poor connection (cold solder joint). If you have a soldering iron, solder (circuit type not pipe type), and a multimeter. Use the soldering iron and solder to redo the cold solder joints , and then test it (the connection) with the multimeter.
I hope this helps
Thank you,
Shuttle83
Sep 25, 2008 | RCA HD52W59 HDTV Projection Television
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Picture getting small blacking out
Yes you sound like pincushin is failing on you. Soon it will knock out horiz. output caps and Diodes. Needs repair soon.
Apr 25, 2007 | RCA F35673MB 35" TV
TV picture
The set you have has a bad tuner assembly. At this point most likely you would be better off getting a new TV set. Good Luck
Mar 30, 2007 | Mitsubishi CS-27309 27" TV
Quasar SP-3233 TV Logo
167 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
