Check closely where the idler bracket was at and also the spring location.
You look for a worn area on the frame of the dryer and also the worn area on the idler arm bracket. Once you locate the right place for them to go, then put your spring on and check to see where it may hook up, there should be a small worn spot to look for...Just remember that the spring will be under tension when it is hooked up. So look for an area that would be worn with the spring
stretched out somewhat.
I will send you a website to check also, they have schematics of dryers and they may be able to show you the approximate location of the bracket.
http://www.partselect.com/ or try this one...
http://www.appliancepartspros.com/index.aspx
Good Luck,
I hope this helps.
