This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help Replacing the dryer coils
Sounds like you need to replace the coils on the gas valve. Just make sure your venting is clear 1st. If it is, the coils are easy to replace. Remove the front panel and the coils are on the bottom right hand side. Two screws and the bracket for both comes off. One has two terminals and the other has three. Real easy once you get into the dryer.
This sounds like a heat related problem, which could be a faulty chip or a cold (bad) solder joint on one of the PCBs (printed circuit boards). Due to the lethal voltages present inside a CRT type television, it is strongly advised to have this repaired by a qualified technician. however, if you or someone you know is technically inclined, you can try to fix this yourself. Cold solder joints can often be spotted by visible cracks in the solder joints. a through inspection of all the boards could easily identify the problem which can be resolved with a quick tap with a soldering iron and perhaps a little extra solder added to the joint. if that yields nothing, another method is heat/cold stressing the boards while the TV is running. With the TV on, spray small areas of the PCBs with cold spray (or a can of compressed air duster turned upside down) until the tv shuts off. then heat the last sprayed part with a hot air gun (or a hair dryer) until you can get the problem to repeat regularly. inspect the area causing the problem and you will probably find the culprit.
If dryer lights for a few minutes and will not stay lit, I believe the solenoid coils will need to be replaced. Click on link below, enter your model number lgr5620kq1 in model search feature and go to the dryer page it shows a breakdown view of your dryer. Also go to common solutions and look for gas dryer problems. I will also be here to help you, Sea Breeze
sounds to me like a temp control problem, perhaps the heating element controller is faulty allowing the temp to rise over the safety cutout switch range, Hence a cooling down time is required to reset the dryer. Try on cold cycle.. If so try it should run ok
