Question about Hitachi 53SWX01W 53" Rear Projection Television
Picture problem When I turned on the TV the whole picture went fuzzy exactly like a 3D movie. The next morning I turned on the TV and no picture came on at all.There is power going to the set and it does not matter what video setting I am on. There is no picture just as though the set is turned off. I can also hear a faint clicking noise when I am at the back of the TV.
  • cktros250 Feb 11, 2009
    my
    Hitachi 53SWX01W 53 in. has a 3d effect when i turn, it on the colors are red blue green, the scape is a anvil shape.
  • Hitachi Master
  • 3,459 Answers
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
    President:
  • 4,402 Answers
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
Hello, I have a L.G. 55LW5300 3D Hello, Hello, I have a L.G. 55LW5300 3D LCD T.V. and it will not turn on?
You need to contact your insurance because that surge destroyed the TV circuit boards.
Sep 28, 2016 | Televison & Video
How can enable 3d on philips led 40pfl8605h?
Do you have the PTA02 accessory for the TV? This is a USB 3D transmitter and comes with 2 pairs of Active 3D glasses. The screen of the 40PFL8605H is not a 3D TV by itself.
Once you have the accessory plugged in, you may need to wait for the software to be installed on your TV before you can watch 3D content. See the manual for the TV for more information: http://download.p4c.philips.com/files/4/40pfl8605h_12/40pfl8605h_12_dfu_eng.pdf . This is on page 73 of the PDF.
I hope this helps. If you have the 3D accessory plugged in, try turning off the TV and turning it back on if the software did not install properly. The final thing to check is the "codecs" for your 3D movies on the USB stick. Make sure that they are compatible with the TV.
Apr 19, 2013 | Philips Televison & Video
How do I view movies in 3D on the Mitsubishi WD-Y65?
WD-Y65 is NOT a 3D ready TV. You either have to change the TV to see the movie in 3D, or just watch it in 2D in you current TV.
I have the same TV as yours. Current I connect a desktop PC to the TV via DVI port, and I watch Avatar using colorcode 3D(Amber/Blue) with Stereoscopic Player from www.3dtv.at It might be a way for you to enjoy 3D without change the whole thing, but it's an entire different topic.
Jan 08, 2012 | Mitsubishi WD-Y65 65" HDTV
I turned My tv on and the top of the screen has red, green, and blue swirl lines, and the rest of it looks like watching a 3D movie without glasses, and the picture looks as if you took out the screen and...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or pictures look like 3D?Yes,than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
Aug 11, 2011 | RCA D52W19 52" Rear Projection Television
Picture went out on my 36'' RCA television, still have sound.
do you have and big sound system if you do the move them away from youur tv. or you sould just bring it to a shop it must be the picture tube
Jan 26, 2009 | RCA 36V430T 36" TV
Picture looks like 3D without 3D glasses on???
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Dec 30, 2008 | RCA HD52W59 HDTV Projection Television
Looks like watching 3D movie(colors) and rounded
This is a convergence problem and is either bad connections on the convergence ICs or defective ICs. If you feel that you can solder, you should be able to repair this yourself. First try resoldering the pins on the convergence ICs. If that fails, replace the ICs. These ICs are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted.
Dan
May 13, 2008 | Toshiba 57HDX82 57" Rear Projection HDTV
Fuzzy picture
Chances are the optics have been thrown out of alignment by the move. They are completely adjustable, but you may require a qualified technician to do the job properly.
Jul 16, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Open Questions:
Blue Ray Compatible? I have had my Hitachi 53SWX01W set for maybe 7 years or so. It is HD ready. My DVD player that I had hooked up to Component jacks #1 crapped out recently and I was using a portable DVD player in the front jacks. Everything always played perfect. I bought a Sony Blue Ray player and a Samsung HD Tuner over Thanksgiving and installed them. HD Tuner on component jacks #1 and the Blue Ray on CJ #2. Both with sound through fiber optic. The tuner was a snap and the picture is great. The Blue Ray was also a snap and Blue Ray disc's play great. My problem is DVD's! When playing a Standard DVD the picture will blank out radomly for 1/2 to 3 secounds and it may do it once or twice per disc or it may happen randomly throughout the disc. Sometimes it will not happen at all and the next day playing the same disc the picture will start blinking out again. There is no interuption in the sound or place in the movie, just a loss of picture! I have traded component jacks between the tuner and Blue Ray, I have change Component cables from very expensive to very cheap and back with no noticable difference. I exchanged the Sony BDP-350 Blue Ray player for another player with no success. I still have the same problems. When veiwing Blue Ray disc's The TV will display 1080i resolution with no problems at all. When playing standard DVD's the TV displays 480p resolution and the blinking problem happens. The Blue Ray player dosen't ramp up the picture quality on DVD's as I thought it would but that could be because I'm not using an HMDI cable which my TV does not have. Please HELP!!! Jim
Dec 17, 2008 | Hitachi 53SWX01W 53" Rear Projection...
Hitachi 53SWX01W 53" Rear Projection Television Logo
173 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
