Question about Rio Carbon MP3 Player
Volume Control on a Rio CE 2100 (2.5 GB)
I dropped my Rio and the volume wheel is now not working.  i looked up the problem on this web site and found a fix for a Rio Carbon (5 GB), but it doesn't seem to be working on my CE2100.  could you please give me directions for how to fix this?  Thanks.
  • 8,596 Answers
This is a hardware issue - there is no repair svc for this one. sorry.
Posted on May 23, 2008
Volume settings on the Rio carbon
I'm afraid that there is not. What headphones are you using? I have found that when many people ask questions like that it is the headphones and not the player. People say that when using the 3.04 firmware (look in tips and tricks for this player), the volume is higher but I haven't noticed a difference personally.. When I put my Rio up to highest volume it would damage my hearing if I could put it up any higher and I can only hear people shouting when it is on full volume. Have you got another pair of headphones/earphones to try? You could buy some high ambient noise reduction earphones and this may help.
Hope this helps,
Sep 28, 2008 | Rio Carbon MP3 Player
Broken Volume Wheel
Sorry, Rio kinda went bust some time ago so to my knowledge there isn't anywhere that does repairs anymore.
See: Replace broken scroll wheel on Rio carbon for help on how to DIY.
Hope this helps,
Aug 15, 2008 | Rio Carbon MP3 Player
Rio carbon can figure out how to get the download into the rio
The 3.04 developers cut firmware gives you a volume control via the bottom of your menu. You can get it from:
follow the link.
Hope this helps,
Btw, i will also be posting a tip on how to fix a broken scroll wheel on a rio carbon soon so have a look in a couple of days (maybe even tonight) and i should have done that.
May 26, 2008 | Rio Carbon MP3 Player
Opening the Rio Carbon to replace the volume button
The easiest and least damaging way to open the Rio Carbon is to start at the bottom of the player and pry it open a little until you can see the tabs. You have to push those to release them. Work you way around clockwise and there are tab a little further into the player, you have to pull the bottom of those out to release them. I did it last night and was able to repair the volume wheel and get the player back together and it works.
Mar 29, 2008 | Rio Carbon MP3 Player
Volume Control
The wheel is attached to its actual contol in 2 microscopic places to allow the wheel to break rather than a major destruction of internal working parts. Should you hit the player in this area you can either live with the player stuck in this volume level or undertake an extremely complicated repair job.
Aug 29, 2007 | Rio CE2100 MP3 Player
Rio CE 2100 : insufficient space to index your content
I would recommend wiping your player:
Windows only.... Please post if you are not using windows...
Open My Computer with your Rio plugged in.
Right click on your Rio carbon and click on format.
Leave the default values - if it asks you something then use your initiative.
Then click on format.
Then when it has finished formatting go to your firmware (can be downloaded from:
Follow the instructions and then it should load the firmware onto your player.
When it has done then your player should (in theory!) work properly.
Hope this helps
Aug 14, 2007 | Rio CE2100 MP3 Player
Rio Forge 256mb volume button broken
I had the same problem. I took it apart and found a plastic piece broken off. I think I'm hosed!
Nov 14, 2006 | Rio Forge Sport Digital Media Player
Broke volume dial This link takes you to a site which will allow you to download an upgrade to your carbon's software which includes a volume option in the settings menu. My wheel broke a while ago too, and I bought a new player before I found this link. I still think this is the most compact and portable 5gb player on the market. I'm back to using it now.
Aug 21, 2006 | Rio Carbon MP3 Player
The reset button is the tiny hole on the top of the player to the left of the volume wheel. Use a paper clip to stick in the hole and push in the reset button for a second. Your screen should turn black and then turn off. Hopefully that will work!
Jul 08, 2006 | Rio CE2100 MP3 Player
Broken volume wheel
It is easier to fix it yourself. Very carefully take off the faceplate (you can put it back on later using a hair dryer). There are two slots there that you can use to release the back casing. I used an eyeglass screwdriver to gently press down on the catch. There are three other catches on the back - one on each side and one on the top by the headphone jack. Be extra careful when releasing the top one. Once you have the back cover off, it is easy to see where the wheel has broken. I used a two-part epoxy on the two places of the volume wheel that had formerly attached it to the control and put it back in place. Once this has dried, replace the back cover and use a hair dryer to heat the adhesive on the face plate. Stick the face plate back on, and you're done.
Dec 04, 2005 | Rio Carbon MP3 Player
Rio Carbon MP3 Player Logo
83 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
