Question about RJ Tech RJ-200S DVD Player
How to switch back to NTSC from PAL without being able to see player menu
I switched TV system from NTSC to PAL and none of mine TV supports that, now I cannot even see player menu only thing I see are stripes all over my tv, so no sound no pic at all. Already tried to switch to defaul settings by pressing OPEN, Prog+Zoom but it didnt do anything. Is there a reset button or can someone tell me how can do it without seeing menu step by step. TY
Solution to resetting TV type for RJ Tech
  1. hook up unit to computer monitor (not a TV)
  2. power up, remove any media from the tray
  3. select setup menue
  4. for TV type - select NTSC
  5. for TV output make sure CVBS S-Video is selected
  6. exit setup
Posted on Oct 19, 2008
Yeah sorry i have the same problem but worst cause i threw out the user manual too. If you can solve it let me know please.
Thank you
Posted on Jan 20, 2008
DVD will not play in color, what am I doing wrong
Hi, are you using a UK pal tv? Chances are you are watching a US region 1 dvd which is encoded in NTSC. This will play in 525 lines and black and white on a UK PAL tv. Does your DVD player have an NTSC playback to PAL tv swich? It would simply be labeled "PAL" and "NTSC" If not on the back then possibly in the menu. If you have the switch select NTSC and try again.
Hope this helps
Steve at Olive Country Computers in Spain
Mar 04, 2011 | Durabrand DVD-1002 DVD Player
I bought pioneer muti system dvd
Check your DVD player's color system, most multi system dvd player has to be set(PAL or NTSC) manually, NTSC for American standard. Look for this button could be a mechanical switch at the back or at the menu. Some machine need to reboot after setting. Hope this helps
Mar 04, 2010 | Samsung DVD-V90K Multisystem DVD/VCR
Rf signal pal to ntsc
there should be an option in your picture settings menu
Jul 23, 2009 | Polaroid FLM-1514B LCD TV
Using pal/ntsc system dvd player in USA - how to setup to work on ntsc tv
You sould have a button on the remote controls thats says Pal/NTSC, press that button to switch.
Nov 07, 2008 | Durabrand Televison & Video
Oritron dvd 3119 player
You have to blindly instruct the NTSC/PAL menu item, which toggles between NTSC and PAL;
This is how it is done:
1) turn your dvd player off.
2) Turn it back on and make sure there is no DVD in the player tray.
This will ensure the menus are active
3) Using the remote, press the dowm menu selector key exactly three times
4) press the center menu select key once.
This will activate the display adjustement menu
5) press the down menu key exactly once.
This will activate the NTSC/PAL menu
6) press the center menu key
DONE.
The player should now have switched back to NTCS if it was in PAL.
IF it was in NTSC it should have switched back to PAL.
Note: If you still have the manual you can follow the menu tree blindly using the instructions in the manual. The above sequence is for activating the NTSC/PAL menu.
This player can also switch to progressive scan, which creates a similar problem. At least the progressive scan menu has enough warnings before it will actvate.
Jul 29, 2008 | Oritron NPD3117 DVD Player
Sony HandyCam SR10(NTSC) working with my Philips 21PT2443 model
Hi Pawan, Now I am in the same situation as you were. I am planning to buy one sony camcorder from US. But it supports only NTSC. But My TV is philips 29PT7322, User Manual says it supports, NTSC and PAL colour systems. But I am not sure it works or not. Can you please help me with your experience. Thanks in advance, Kinod
May 05, 2008 | Televison & Video
Switching form PAL to NTSC
did you tried to switch back to factory settings? thanks
Apr 11, 2008 | Bose Lifestyle 38 System
RCA RC5215P DVD Player only plays in black & white
Dear brother at first u insert a original copy righted disk and check .And there is an option for swithing in menu for PAL and NTSC.And also please check ur TV is supported NTSC3.15 colour system,If not check ur player in a multi system TV.
Dear brother if u r a technician please can u mail me the IC number of IC104 in signal board under the lense mechanism in the same RCA RC5215P DVD player,becouse I have missed this IC from my player
Jul 15, 2007 | RCA RC5215P DVD Player
Pal/Ntsc playing problem
is your tv is the same tv that u playing before? coz according to you if u play ntsc there is no problem. if ur tv is multisystem, u can change the tv system menu to auto, but if not u cannot watch coz ntsc tv only accepts ntsc signal.
Jan 08, 2007 | Pioneer DV-373 DVD Player
RJ Tech RJ-200S DVD Player Logo
424 people viewed this question
Top RJ Tech Televison & Video Experts
Tom Chichester
Are you a RJ Tech Televison and Video Expert? Answer questions, earn points and help others
